AC delete belt size
Former Vendor
There are two different belts, depending upon what year your car is. Early cars and 924S models use 5 X 736 - 99919220450.
If you have a late 944, you can use the 6 X 720 belt that Vinnie lists below - 99919229050
Last edited by ECS Tuning; 11-02-2012 at 03:29 PM. Reason: Early and late models use different belts
Hates Family Guy
It's the pulley on the alternator that determines which belt to use. Early cars had 5 groove pulleys, late cars have 6. Make sure all your pulleys match if you're replacing the alternator.
