Show me your tool (thermostat removal)
Old 08-30-2012, 02:06 PM
StoogeMoe
StoogeMoe's Avatar
Exclamation Show me your tool (thermostat removal)
This is the tool I have used in the past to remove the snap ring for the thermostat. I found out it is broke. So I need to get a replacement. Show me what you use to get in that tight space.
Old 08-30-2012, 02:09 PM
Reimu
Reimu's Avatar
Just ordered my thermostat last night
Will be monitoring this thread
Old 08-30-2012, 03:48 PM
BG993
BG993's Avatar
I just have a large snap ring plier....
Old 08-30-2012, 04:31 PM
Will Feather
Will Feather's Avatar
+1 with 45 degree angles on them.
Old 08-30-2012, 11:28 PM
cas951
cas951's Avatar
Tried this tool once. Great design but poor qaulity. It broke as soon as I put tension on the tool and I ended up throwing away.
I used this to test right when I installed my new pump before buttoning things up. Worked great. Note: I grinded the tips to fit the snap ring.
Harbor Freight special.
Old 08-31-2012, 01:58 AM
F18Rep
F18Rep's Avatar
Yepper, BTDT (only, I think my tool is the long reach version - the pliers, I'm talkin about the pliers)...Bruce ;]
Old 08-31-2012, 03:37 AM
Techno Duck
Techno Duck's Avatar
A good pair of 45 or 90 degree snap ring pliers will work, the absolute most important thing is the direction the snap ring is facing. One way will take a few minutes to get out, the other way will take you an entire day.
Also wear eye protection when you work on it.. the likely hood of breaking a tool is high and it can send that thing flying.
Freaken snap ring...
Old 08-31-2012, 12:13 PM
Tom M'Guinn
Tom M'Guinn's Avatar
What the world needs is a fool-proof specialty tool that will get at that snap ring without fuss, no matter how corroded in there... I'm just say'n...
Old 08-31-2012, 02:15 PM
StoogeMoe
StoogeMoe's Avatar
I hope I put in the right way when I put in the water pump. I put it so the opening is towards the bottom of the pump. Maybe around the 6 o'clock or 7 o'clock position.
I wonder why that snap ring is so strong? It's not under a lot of pressure. Maybe just a bit of temperature extreme. It sure would be easier if it was 1/4 as hard to squeeze.
Old 08-31-2012, 03:06 PM
Duston944
Duston944's Avatar
http://www.harborfreight.com/hand-to...set-97406.html
This worked for me.
Old 08-31-2012, 03:48 PM
Lightningmcnulty
Lightningmcnulty's Avatar
I used a pair of needle nose pliers with good teeth to get mine out last night, no problem at all took less than 30 seconds.
Of course my water pump was out of the car but I think you could probably use the small angled needle nose pliers
Quick Reply: Show me your tool (thermostat removal)
