Couple questions about my newly acquired 1988 944 base.
I've got an, according to carfax and my title, a base model 1988 944 with a 3.0 that has never been wrecked.
It has a new style dash with no passenger side air bag and driver's airbag; which was standard in 88 right?
It has a LSD, which I checked myself after I noticed it felt funny when I lost traction in the rain the other day.
It's also got ABS and the bigger front brake calipers.....
It has also got a lot more power than my 90 model rx7 did. Though the rx7 was suppose to be faster...
Needless to say I'm very confused as their are only three option codes listed and none of them are important..
I'm going to look at the code on the engine block later but I'm just trying to figure out if there was a reason for all the missing standard parts...
If you have an 88 it is a 2.5L engine. Airbags were an option only and didn't become standard until 1990. You have LSD, that's a plus
Post the vin# and pics and we'll tell you more.
88 NA had optional airbags, they were standard on the turbo from 87..
Can you post up some pictures?
I didn't know that about the airbags.
The VIN I'll post when I get off.
I know the 88's had 3.0's and its just a dmv mistake.
But it has A LOT more power than it should....
How much can you build a 88 2.5?
I know it was rebuilt 6,000 miles before it was parked for 10 years.
US 944's to 87 had 143hp, 88 had 160hp, 89 had 165.
Mainly from piston changes: to 87 9.5cr, 88 10.2cr, 89 10.9cr.
Doubt it had an engine swap, not likely in 2002.
Maybe what he has is actually an RX-7, and you just can't read the "1." in "1.3L"
Almost Addicted
Seat of the pants, the 2.5 88 NAs feel noticeably faster than the earlier cars, they have the higher compression ratio and a short 5th which makes it feel a little peppier at freeway speeds.
