Homemade adapter for injector cleaning
I had some old injectors laying around so I made a adapter to clean them with carb cleaner.It is just a welding tip(the inner part of it )another smaller welding tip soldered on the top of it for the small rubber hose which connects to the red plastic pipe from the can.I also glued a piece of plastic vacuum line on the red line so that it fits the size of the rubber hose.The only problem with it is that you need 3hands or somebody to help you because the pressure pushes the adapter from the injector(I have to think about something to hold them together)but other than that it works really good.
