View Poll Results: street combo; de-stroked LS7 388 c.i. vs LS3 376 c.i.; which would you run ?
LS3 376 c.i. (Crate Engine Depot); $7,300 (see top of page 4)...
27
60.00%
LS7 block w/ ls3 crank @ 388 c.i., LS3 heads/intake LS7 cam; $9,900.
18
40.00%
Voters: 45. You may not vote on this poll
LS1 swap/parts/LSD transmissions...
Old 09-03-2010, 10:37 AM
Hotshoe
Hotshoe's Avatar
Is the crossmember really necessary?
I was just going to do a tasteful hood blister ala BMW M3 to allow for additional clearance. I wasn't aware any steering rack issues.
Old 09-03-2010, 11:22 AM
83 944's Avatar
IIRC from what i hear you need a crossmember if you use the stock oil pan and crossmember.
Old 09-03-2010, 11:29 AM
83 944's Avatar
also i would love to get that oil pan, with the motor mounts if its cheaper than the crossmember, and where is this QT bellhousing?
Old 09-03-2010, 11:38 AM
MN944S
MN944S's Avatar
Originally Posted by 83 944
..and where is this QT bellhousing?
http://www.quicktimeinc.com/products.html RM-6033
Old 09-03-2010, 12:26 PM
LS1Porch
LS1Porch's Avatar
Not possible, the throttle body at the very front is what hits. You would have a bulge in the very tip of the hood that would have to extend into the header panel.
Believe me, it's all been thought of and tried!
Old 09-03-2010, 12:58 PM
alex
Almost Addicted
alex's Avatar
No, it isn't necessary, but I really liked the idea of not having to mess around with a custom pan and hood clearance issues, and as I mentioned, the cost is pretty close. You can either bolt uprights and setback plates to the old one or get something that is purpose built. The steering issue only comes in because the new xmember drops the rack mount a bit, if you stick with the stock xmemeber, it is not an issue(as far as I know). However, I much prefer the design of the of the new tie rods/ends.
Old 09-03-2010, 01:52 PM
Hotshoe
Hotshoe's Avatar
So if I understand correctly the fit issue is only with the stock pan? I have a custom pan from RH that I was going to use unless I went with a dry sump LS7.
Old 09-03-2010, 02:28 PM
xschop
xschop's Avatar
A few people have done the MOROSO 20140 pan as it is the easiest to mod off the shelf and sets the lowest. I also developed a transmission mount that allows the V8 driver's head to set 1/4" away from the firewall so the Throttle body clears the hood alot better and the intake boot clears the hood latch if it is kept. I have a 1.25" X-member drop and still had to angle the throttle body top extrusion. These bodies all have different variances/tolerances in the chassis. I think mine was built during OKTOBER drunk fest.
Old 09-03-2010, 03:58 PM
alex
Almost Addicted
alex's Avatar
A couple things....
There are numerous ways to do this, and as long as it works, and will hold up, it may be a matter of preference. Since I am building mine in my garage, the xmember seemed to be the best bet for me- I've read about some modded pans leaking. I am not sure how widespread it is or if it was just a few hacks gluing them together in their garage that was the problem; but for me, the idea of being able to drop the whole engine in without buying or fabbing a custom pan was appealing- if you were to rate my welding, it would be fall between "unacceptable" and "terrible"- this is the oil pan here, I'd rather not find out how bad my welding is while driving the car. As far as I know, even with the custom oil pans, there can still be hood clearance issues, but don't quote me on that. Suffice it to say that the economics and the logistics made the tubular xmember a good idea, in my case at least. Also, the plan (we'll see how it goes) is to drop the entire engine, stock xmember attached, all at once, so there is no extra effort involved. I need to remove some of the turbo plumbing, exhaust system, and make sure there aren't any grounds or other wires attached, and I'll be ready. The goal is to have the turbo engine out by tomorrow. We'll see.
Old 01-02-2011, 06:49 PM
arthropraxis
arthropraxis's Avatar
Are you going to do a conversion? That 5.3 is a good price.
Old 01-02-2011, 07:40 PM
xschop
xschop's Avatar
If anyone decides they want an LS4 in their 944/68, there will be a TT adapter plate to fit a BH with that pattern.
Old 01-06-2011, 10:08 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Default 6 speed transmission for top end speed now built...
we know that running a 944T 5 speed with a n/a variant 5th gear can make up to 175mph ++ of top end, but many of the guys have been researching for some time how to set 968 transmissions up for more top end without breaking the bank.... at one time i was under the assumption that any and all Audi 01e 5th and 6th gearsets were interchangable with the 968. apparently, not so... but the one set from the 2wd european diesel cars are a perfect match and can be used to make extreme top end...
if you choose the 968 transmission, you basically have 2 choices for 5th gear: the stock .912 gear (which is too low), or a .729 5th available from the A4 diesel, being the far better choice, (now installed)... consult w/ Scott Dewitt at Advanced Automotion for correct part sourcing... it causes a significant rpm drop after shifting out of 4th, but really leaves the driver with maximum flexibility on for reducing the rpm on the secondary roads/slower highway speeds, etc....
the .729 5th grear will make about 160 mph @ 6,000 rpm (running a 25.6 inch tire)....
you have 2 choices for 6th gear... either a .600 or .680.... i went with the the .600 6th gear will make 195 mph @ 6,000 rpm, or about 188 mph running a 25 inch tire... and the gearsets will bolt right into the spare 968 box.... the .680 basically makes a perfect top gear for turbo or supercharged 968s.
Scott Dewitt at Advanced Automotion, Corpus Christi, TX has a vast knowledge all the Audi 01e, and 968 boxes, and how to perform these gear retrofits for perfect results. he was an invaluable resource for sourcing my gears.
http://www.advancedautomotion.com/
other extremely knowledgable sources:
Roger at California Motorsports, Lake Havasu, AZ
http://www.californiamotorsports.net/
for 968 trans rebuild parts; JH Motorsports, California....
http://www.jhmotorsports.com/shop/catalog/home.php
Jerry Janzing, All Pro Cars (the GT40 people like the Audi A4 diesel, 944, and 968 transmission);
http://www.allprocars.com/web/
Old 10-10-2011, 02:39 AM
odurandina
Team Owner
odurandina's Avatar
Default Z06 oil cooler or other unit... suggestions ?
it looks like this cooler could have multiple applications for our cars, but trying to determine if the long singlepass, Z06 coolers or nascar style doublepass coolers would make the best fit and leave me the most separation from the ac condenser (for stuck in traffic on the hot days context with the 376. c.i. engine).... with the LS3, the remote oil filter will begin on the driver's side of the block....
http://forums.corvetteforum.com/c6-t...oil-lines.html
wondering if this presents any problems for mounting the remote filter in the downward orientation on this side of the bay or if the overflow reservior presents a problem... thinking that i want to lean the Z06 cooler as far over toward the driver's side inlet duct as possible as to have it shroud the radator flow area as little as possible....
also wondering what remote filter kit to get that will mount to a set of stock Z06 lines....
i know Docwyte is running a Mocal 11x8x3 cooler with a 180 thermostat.
but i've been checking on a couple of big, doublepass coolers available for about $300...
http://www.outlawraceparts.com/produ...er-1513-0.html
http://cgi.ebay.com/ebaymotors/Fluid...m=350358809042
i guess if i do go with one of these others, i'll need to figure out how to run a thermostat as well.
any thoughts?
Old 10-10-2011, 09:10 AM
Lemming
Lemming's Avatar
This is what I'm using.
http://cgi.ebay.com/ebaymotors/30-Ro...#ht_4622wt_956
Old 10-10-2011, 10:12 AM
dirtyTurbo
dirtyTurbo's Avatar
Originally Posted by Lemming
As a college student who enjoys researching parts I can't afford, I'd like to say that is an excellent deal
Quick Reply: LS1 swap/parts/LSD transmissions...
