GROUP BUY: Engine harness connectors:GB IS CLOSED!
OK Everyone, we all have wondered... "Where can I get a new connector for ..."
Well, I have found a source, that carries a full setup of Bosche connectors, seals, pins, and boots. They also carry a few other interesting bits I have included for the purpose of this buy. (I have a request in to try to get 5 pin male connectors for those MAF users who don't want to cut up their AFM, or engine harness).
I have broken the pricing for this up a bit, First we have individual items, the connectors, boots, pins and such are individually listed, except where noted as "SET". Pay attention to the bits at the bottom of the list, as these are not for everyone, but I figured I would include them, as I know SOME people are using these! Also included is the famed "044" fuel pump. (OF NOTE: THE REFERENCE SENSOR CONNECTORS ON THE SENSOR ITSELF ARE 3M IN THE LIST BELOW)
Description ---- Price
CONNECTOR HOUSINGS - FEMALE
PLUG HOUSING 2 PIN, FEMALE ----- $1.93
PLUG HOUSING 3 PIN, FEMALE, GRAY ----- $2.33
PLUG HOUSING 4 PIN, FEMALE ----- $2.98
PLUG HOUSING 5 PIN, FEMALE ----- $3.11
PLUG HOUSING 6 PIN, FEMALE ----- $4.70
PLUG HOUSING 7 PIN, FEMALE ----- $4.33
CONNECTOR HOUSINGS - MALE
CONNECTOR PLUG 2 POLE MALE ----- $1.66
3 pole connector housing, male, (JPT) ----- $1.72
PLUG HOUSING 4 PIN MALE ----- $4.19
BOOTS
Short boot for 2 pole connectors ----- $2.36
PROTECTIVE CAP FOR 2 PIN ----- $2.49
PROTECTIVE CAP FOR 3 PIN ----- $2.44
PROTECTIVE CAP FOR 4 PIN ----- $2.98
PROTECTIVE CAP FOR 5 PIN ----- $2.93
PROTECTIVE CAP FOR 6 PIN ----- $3.86
PROTECTIVE CAP FOR 7 PIN ----- $3.66
CONNECTOR PINS
JPT Female pin up to 15 gauge wire ----- $1.20
JPT Female pin larger than 15 gauge wire ----- $1.23
JPT Female pin up to 15 gauge wire, Cold plated ----- $2.33
JPT Male pin up to 15 gauge wire ----- $1.20
JPT Male pin larger than 15 gauge wire ----- $1.27
WIRE SEALS
JPT seal, blue ----- $1.07
JPT seal, white ----- $1.07
SINGLE-WIRE BLIND PLUG ----- $1.47
ODDS AND ENDS
PROTECTIVE CAP (Fuel pump terminals) ----- $4.06
Extraction tool for JPT pins ----- $52.87
Connector GM 3 Bar MAP + pins + seals ----- $6.32
Injector Connector set EV6/EV14 USCAR + pins + seals ----- $3.00
Injector Connector ND/Sumitomo type SET ----- $3.00
ELECTRIC FUEL PUMP "044" (P/N 0580254044) ----- $180.56 (I HAVE conformation these are authentic Bosche 044 pumps made in the Czec republic, my source has been an authorized Bosche distributor for over 20 years, included is a picture taken of the pumps being offered!) Circled in the picture below is the OEM Bosche date code, which my source for these was kind enough to break down the coding for me... these are the real deal! FWIW the pump pictured (date code 002) corresponds to FEB 2010.
Next, I broke out individual connector sets, 2F indicates a 2 pin FEMALE PIN connector (Our OEM Bosche injector connection) SET (a set includes the connector, pins, wire seals, and the connector boot). (OF NOTE: THE REFERENCE SENSOR CONNECTORS ON THE SENSOR ITSELF ARE 3M IN THE LIST BELOW)
2F ----- $4.02
3F ----- $4.67
4F ----- $6.16
5F ----- $6.54
6F ----- $9.36
7F ----- $9.09
2M ----- $3.69
3M ----- $3.97
4M ----- $7.25
Lastly, I present complete engine bay connector sets, these sets are ALL the Bosche connectors in your engine bay listed for both N/A and Turbo 944 family. These sets are comprised of TPS connector, AFM connector, Injectors, Knock sensor (turbo only), ISV connector, DME Temp sensor connector, Reference sensor connectors (harness side), and N/A air valve (rear of the intake). If you want to add the MALE 3 pin connectors for the reference sensors let me know, and I will bundle it that way for you. I also priced out the 61 female pins needed for the DME and KLR plugs.
951 ----- $38.91
N/A ----- $34.70
968 ----- $47.18 (13 connectors total, by far the most!)
DME / KLR pin set ----- $13.20 (pins only, 61 in all)
Flat rate of $15 for shipping / handling PER ORDER to cover repackaging and sending to you via USPS Priority flat rate for US ORDERS ONLY, international orders MAY incur slightly higher shipping charges.
Payment due to secure your order.
Payment can be sent via PayPal to johnkoawood@aol.com. Please make sure you include in the text of your payment WHAT you are ordering, and make sure you include your address. Cash or Money order can also be accepted, however you don't have much time to get your payment to me, PM me for my address, and I will mark you down as payed on receipt.
Let me know if you have any questions, comments, or need something "special". If you have any questions regarding totals, or pricing please PM me, I will work with you to address each item you need, and MAY customize a quote specifically for you.
But hurry, this GB will be ending NOW 25 JULY 2010 and will be placing the order at that time. Lead time is minimum of 1 week, possibly longer for some items, depending on volume of our order, and specifically what is ordered.
FWIW, I am ordering a full set of connectors for my personal 951, a set for my N/A a pin tool, extra pins, and an 044 pump. My order secured the pricing for this sale. IF there are any proceeds from this sale, I will be forwarding them to PROJECT RENNWISH "Kelly's Kids". I will match the donation, with one of my own of not less than $50.
HAPPY MOTORING!
Default GROUP BUY: Engine harness connectors:UPDATE ADDED 968 CONNECTOR SET!
BOOTS
CONNECTOR PINS
WIRE SEALS
ODDS AND ENDS
2F ----- $4.02
3F ----- $4.67
4F ----- $6.16
5F ----- $6.54
6F ----- $9.36
7F ----- $9.09
2M ----- $3.69
3M ----- $3.97
4M ----- $7.25
951 ----- $38.91
N/A ----- $34.70
HAPPY MOTORING!
PAID:
1) Tom M'Guinn (951 engine set, extra pins)
2) Yuliang Ruan (Reference sensor complete set)
3) Pete Laches (N/A connector set)
4) CurlyDE (2x 951 kits, 1x 944 kit, pin extractor tool, 3x DME/KLR pin kits)
5) RedLineMan (2x N/A kits, 2x 944T kits, 2x extra pin sets)
6) Brian Broderick (951 Kit)
7) JoshB (2x 951 Kits, 2 DME Pin sets)
8) Techno Duck (2F and 6F connectors)
9) Mikerex (N/A Kit and 2 3M connector sets)
10) Shane Knapp (951 Kit)
11) DanG (951 Kit)
12) Christopher Ching (2 3M sets)
13) Julian Allen (4 fuel pump caps, Extractor tool, 20 each of each type of female pin)
14) Manuall Fernandes (951 Kit)
15) Kevincnc (N/A Kit)
16) CgkingTX (N/A kit and extractor tool)
17) thetintmaster (951 kit, and 2 3M sets)
18) 67King ( 951 Kit and 2 3M kits)
19) jlturpin (951 kit x2, 3M set x4 and an extractor tool)
20) Pauer Tuning (32 EV6/EV14 sets, 32 2F sets [16 short and 16 long boots], 24 3F sets, 10 6F sets, Extractor tool)
21) Keith Belcher (951 Kit, 3M kit x2, DME/KLR pin set and a tool)
22) Danny8774 (951 Kit, DME/KLR pin set, Extractor tool)
23) oazix (968 Kit)
24) dillon410021 (951 kit, DME/KLR pin set, Extractor tool)
25) Vitesse Racing (Per separate quote)
26) I8A4RE (N/A kit)
27) tommye (951 kit, DME/KLR pin set, Extractor tool, fuel pump terminal caps)
28) LUCKYJACKASS (951 Kit, 3 3M kits, 4 Fuel pump caps)
29) MikeV (2 Fuel Pump Caps, DME/KLR Pin Set, 1 6M kit)
30) E Hall (2 3F kits)
31) Curt P (951 kit and extractor tool)
32) Dave Mcgrath (per seperate quote)
33) disasterman (951 kit (x2), DME/KLR pin set (x2), extractor tool)
34) Chris White (per seperate quote)
35) Rluciano (951 Kit, N/A kit, DME/KLR set, extractor tool)
36) Chris Pacitto (per seperate quote)
37) mtnman82 (951 Kit, DME/KLR pins. Extractor tool)
BOOTS
CONNECTOR PINS
WIRE SEALS
ODDS AND ENDS
2F ----- $4.02
3F ----- $4.67
4F ----- $6.16
5F ----- $6.54
6F ----- $9.36
7F ----- $9.09
2M ----- $3.69
3M ----- $3.97
4M ----- $7.25
951 ----- $38.91
N/A ----- $34.70
HAPPY MOTORING!
BOOTS
CONNECTOR PINS
WIRE SEALS
ODDS AND ENDS
2F ----- $4.02
3F ----- $4.67
4F ----- $6.16
5F ----- $6.54
6F ----- $9.36
7F ----- $9.09
2M ----- $3.69
3M ----- $3.97
4M ----- $7.25
951 ----- $38.91
N/A ----- $34.70
HAPPY MOTORING!
PAID:
11) DanG (951 Kit)
23) oazix (968 Kit)
Right, how much for all the connectors in the 951 harness (sans the connectors at the DME and KLR I presume), plus the rubber boots, plus seals, plus the pins (with spares since some invariably get screwed up). Appreciate the effort! Sign me up.
Yup, $38.91 + $15 S&H complete engine bay connector SET, complete with Pins, connectors, wire seals, and boots, Delivered to your door. Sorry, but I AM working on DME and KLR connectors, don't have them tracked down just yet.
I will even throw in a few spare pins for each set... Add another $13.20 and you can get enough pins to completely repin the DME and KLR connectors in your car now... imagine all new harnesses!
I need the connectors as I am going stand alone, and am building my own harness, all brand new... figured as the pricing was good for the pieces I would offer it up to everyone out there with cracked TPS boots / connectors as well!
I have used some of these, but the catalog recently got updated... and expanded!
John have you got your crank trigger stuff all sorted out as i can double up on my set up when i machine my trigger wheel..?
doe's this great sorce have other delco mitsu nippon tyco etc plugs ? is there a bosche workshop kit available with the tools pins and boots so one can determinate repair and recycle I'm also after some 2 pin male plugs that would effectivly simulate and injector..
nice work john
nice work john
I would need access to a 968 to verify... or if anyone can pop their hood and give me a count of the connectors on the engine harness, and the pins per connector I can price it up for the 968s.. I just didn't have one here (I only own an N/A and a Turbo!)
Again, is someone can verify what is on the S2 harness, I can price a kit up to include everything in a kit (and be able to advise on specific connectors!)
ALL PMs HAVE BEEN REPLIED TO, THANK YOU TO EVERYONE FOR THE RESPONSE SO FAR... CAN'T WAIT TO SEE WHAT THE REST OF THE WEEK BRINGS!
968 and 944S2 connectors / pin counts
If someone gives me a connector, and pin count (connector X pins Y) for EACH connector on the S2 and the 968 I would gladdly add a 968 and S2 kits to the GB list!
Someone... Anyone....
I need to know
Knock Sensors
AFM
TPS
Injectors
ISV
Cam tensioner (for variocam)
any other connector on the engine harnesses....
I need to know
Knock Sensors
AFM
TPS
Injectors
ISV
