89' 944 exhaust smell inside?
Old 04-21-2003, 09:17 PM
Trust me
Trust me's Avatar
Question 89' 944 exhaust smell inside?
Can anyone tell me why I am getting a exhaust smell in my 944? I took out the bad emission tube and plugged the hole in the pipe. Still got the smell. It comes and goes.????? Could it be the back hatch seal? Don't see any cracks in the header. And,no visible smoke. Seems I get the smell most when I down shift. Any help would be great. Not scared to turn a wrench. Thank you.
Troy <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old 04-21-2003, 09:47 PM
Perry 951
Perry 951's Avatar
Post
Most likely it is the rear hatch seal. If you have rattles or sqeaks, they should get better with the new seal too.
Welcome to the list!
Old 04-21-2003, 09:50 PM
Devia
Devia's Avatar
Post
Be careful! You could get a carbon monoxide buildup that could be deadly; I suggest strongly driving with all windows down, and fix that ASAP!
- Julie
Old 04-21-2003, 10:15 PM
Trust me
Trust me's Avatar
Post
Perry,The rear hatch does not squeek or seem loose?
Julie, Thanks. Windows have been down and top cracked open. Very good advise to anyone with exhaust leak
Old 04-22-2003, 04:44 AM
Devia
Devia's Avatar
Post
Thanks...learned the hard way, heh, on a different car.
- Julie
Old 04-22-2003, 04:58 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Devia:
<strong>Be careful! You could get a carbon monoxide buildup that could be deadly; I suggest strongly driving with all windows down, and fix that ASAP!
- Julie</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">what she said..
The hatch seal seperates with age. check the gap at the seal near the center back OF THE HATCH. Carbon monoxide killed my best friend- its nothing to toy wIth!
Old 04-22-2003, 05:10 AM
cheetah chrome
cheetah chrome's Avatar
Post
welcome troy,
my car use to have some fierce cabin fumes, i now have none...this is what i did:
-replace rear hatch seal as perry pointed out
-there are 3 drains/openings in the spare tire well (1 dead center in the bottom; 2 along the passenger side of the well), plug them up
-separate the gas cap overflow drain and the sunroof drain, theres an excellent write up on this..gimme a sec to find it <a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic;f=18;t=002692" target="_blank">fumes post</a>
i'd love to set a wind tunnel pic of the 944/51 w/ the smoke flowing over the car. i know this series of cars has an excellent coefficient of drag, but i'd like to see if it forms a "pocket of smoke right behind the taillights.
Old 04-22-2003, 06:05 AM
Jamie Parkinson
Jamie Parkinson's Avatar
Post
hey troy i used to have that problem with my old 924s but it only occurred when i drove with the sunroof open!!?? strange huh
Old 04-22-2003, 11:23 AM
Perry 951
Perry 951's Avatar
Post
The area below the spoiler is of low pressure when you are at speed. When you open the sunroof, you create a vacuum in the cabin, and it will draw air from that low pressure area. If the seal is worn or seperated, it will suck that exhaust right in.
Been there, done that.
Old 04-22-2003, 08:37 PM
Devia
Devia's Avatar
Post
Like I said, all windows DOWN, didn't say anything about being UP!
Fix it, ASAP! Hate to see you die from it.
- Julie
Old 04-22-2003, 08:53 PM
Trust me
Trust me's Avatar
Post
Wow, You guy's (and gal's) are great!!! Guess I will checking around that hatch seal spare tire. Sauerkraut, I would like to see that "fumes' post if you can find it.
Thanks again, Troy
Old 04-22-2003, 09:00 PM
JLeake
JLeake's Avatar
Post
I had a smell in the cabin that turned out to be fuel from a leaking intake manifold gasket (only smelled it under boost, obviously). The climate control system brought the air into the cabin. If you are sure the odor is that of exhaust then this problem does not apply to you, however it is worth consideration.
Old 04-22-2003, 09:28 PM
Untier
Untier's Avatar
Post
mine was from a bad gasket exhaust leak under the car, came up thru the shifter mostly.
Old 04-23-2003, 02:45 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Post
Perry is actually right. Opening the windows/sunroof will pull the exhaust into the car. Best bet is not to drive it until it's fixed. However, driving with all windows down won't get rid of the smell, but the fumes shouldn't concentrate enough to hurt you (unless you're on a LONG drive. Don't drive accross country! <img border="0" title="" alt="[Wink]" src="wink.gif" />
Old 04-23-2003, 02:52 PM
Skitch
Skitch's Avatar
Post
Don't forget to check your inner shift boot. I had a hole in mine and it was letting fumes in only when it was in certain gears. It got worse if the windows were down.
Quick Reply: 89' 944 exhaust smell inside?
