Lindsey Racing balance shaft dele kit? - Rennlist Discussion Forums
924/931/944/951/968 Forum
SPONSORED BY:
Thread Tools Search this Thread
Old 01-23-2010, 12:56 AM   #1
ChazTech
User
ChazTech's Avatar
Question Lindsey Racing balance shaft dele kit?
So the balance shaft delete kit from Lindsey racing is cheaper than pulleys and belts. Does anyone use this delete kit? Does it vibrate like crap?
ChazTech is offline   Reply With Quote
Old 01-23-2010, 02:18 AM   #2
luftpirate
User
luftpirate's Avatar
Yes that's why the motor has balance shafts....
luftpirate is offline   Reply With Quote
Old 01-23-2010, 03:11 AM   #3
I_am_imprezed
User
I_am_imprezed's Avatar
while driving my balance shaft belt skipped some teeth and i lost my balance shafts. It was pretty harsh and not pleasent. For racing i guess it would be alright but theres no way imo you can run without balance shafts in a street car or why you would want too??
I_am_imprezed is offline   Reply With Quote
Old 01-23-2010, 03:14 AM   #4
alxdgr8
alxdgr8's Avatar
If your rotating assembly is balanced then it's not bad...but definitely not adviseable on a stock engine.
alxdgr8 is offline   Reply With Quote
Old 01-23-2010, 03:34 AM   #5
drift a 944
Super User
drift a 944's Avatar
Running no balance shafts on my n/a car and a friends car for about a year. Oil pickup tube reinforcment iis highly recommended. Minor vibration at certain RPM's occurs, but no big deal really. If the belt skips a few teeth then it will be much worse than not running the belt at all.
Not sure about the balance shaft delete kit though...
drift a 944 is offline   Reply With Quote
Old 01-23-2010, 04:03 AM   #6
Reimu
Super User
Reimu's Avatar
There's a couple of HUGE threads on the subject, I think the general consensus is to keep them unless it's a trackcar and you know what you're doing.
Reimu is offline   Reply With Quote
Old 01-25-2010, 12:22 AM   #7
ChazTech
User
ChazTech's Avatar
Exclamation
Quote:
oh wow had no idea! whoda thunk it? balance shafts balancing the motor? NO WAY i was looking for reality answers like how bad it is, cause in my shop we dont do performance we do service and repair. best shop intown, i will be RACING soon and wondered if i should or should not use them. thanks guys guess it was a bad question
Old 01-25-2010, 01:32 AM   #8
derekvg
User
derekvg's Avatar
i'm not running the balance shafts on one of my racers.
purely because its one of the few modifictions alowed in the cup.
maybe you'l gain 1-2 hp with it... but every little bit is welcome in our strict regulations.
i still got original engine mounts (regulations) and to be honestly, i don't really notice it while racing.
on my other racer i will keep them, since alot more mods are alowed in the cup i'm building that one for, so it's not necessary to gain hp.
better for the egine, better for the car.
derekvg is offline   Reply With Quote
Old 01-25-2010, 01:50 AM   #9
I_am_imprezed
User
its not a bad question just seems to me if you have to ask then you probably dont need it...unless you're a hardcore racer in which case you would just know..
Old 01-25-2010, 04:25 PM   #10
Weston
User
Weston's Avatar
Quote:
Yup, it's a good way to crack your oil pickup tube (oil starvation = quick engine death), fuel rail (late 944's; causes huge engine fire), and loosen bolts. Not worth it at all.
Weston is offline   Reply With Quote
Old 01-25-2010, 04:32 PM   #11
Charles A. Toupin
Charles A. Toupin's Avatar
Quote:
^^^^ What he said ^^^^
Most of the guys (racers) I know are putting the balance shafts back because of these 2 main specific failures.
c.
Charles A. Toupin is offline   Reply With Quote
Old 01-26-2010, 11:12 PM   #12
ChazTech
User
ChazTech's Avatar
awesome answeres, thank alot guys, im starting my novice license and will be getting my competition soon, see you in p1 at sebring!
Old 01-27-2010, 01:02 AM   #13
drift a 944
Super User
You ought to bring your car out to this: http://forums.rennlist.com/rennforum...ferrerid=49442
Related Topics
Thread Thread Starter Forum Replies Last Post
LR balance shaft delete kit FS: boost feen 944 Turbo and Turbo-S Forum 1 03-27-2016 02:11 AM
Balance Shaft Delete? JohnKoaWood 924/931/944/951/968 Forum 20 09-14-2009 08:57 PM
Balance Shafts rlm328 944 Turbo and Turbo-S Forum 15 06-22-2009 01:56 AM
New balance shaft/camshaft metal races not fitting billthe3 924/931/944/951/968 Forum 15 06-27-2007 03:30 AM
Tags
944, balance, balancer, belt, delete, forum, gain, horsepower, kit, lindsey, porsche, racing, removal, remove, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
