It's On!!! Official Group Buy: Gear Reduction Starter
Old 08-26-2014, 11:31 AM
  #121
Sysgen
Sysgen's Avatar
Ok, never mind, I`ve figured a way to make it fit.
Old 08-27-2014, 08:38 AM
  #122
Toran
Toran's Avatar
Hello Sysgen,
How did you do it? I may run into the same issue and would like a solution before I am on my back, under the car with only a few inches to work with.
T.I.A.
Old 08-27-2014, 09:22 AM
  #123
Sysgen
Sysgen's Avatar
I used a hammer and re-shaped the aluminum shielding. This gave me the few millimeters needed to rotate it in place.
Side note, on mine the threading on the flange did note match the threading of the stock bolt, had to find another bolt for some reason.
A little video of before and after.
AkechiMotors (04-12-2024)
Old 08-27-2014, 09:47 AM
  #124
Toran
Toran's Avatar
Thank you Sysgen!
Much appreciated.
Old 08-15-2016, 03:49 PM
  #125
Adonay
Adonay's Avatar
How are these starters holding up.
Was cranking the engine the other week to build oilpressure and voila after 3 years standing the starter went boom with smoke after a few short bursts . So i think this starter looks good but would like a little feedback from users that had it for a while
Old 08-15-2016, 04:05 PM
  #126
ideola
Former Vendor
ideola's Avatar
7 years no trouble in my 941, and 5 years no trouble in the Club Sport.
Old 08-15-2016, 06:56 PM
  #127
Cole
Cole's Avatar
I got mine on the original group buy and it's been flawless.
I have even used it to pull the car onto the trailer a couple of times after other non-starter issues.
Old 08-16-2016, 05:04 AM
  #128
Adonay
Adonay's Avatar
Thank you for the feedback! Figured ideola as slightly biased but you convinced me .
Old 08-16-2016, 10:19 AM
  #129
touareg
touareg's Avatar
Nothing for a 968 I assume?
Old 08-18-2016, 01:43 PM
  #130
ideola
Former Vendor
ideola's Avatar
We need a core starter from a 968 to ensure fitment. I don't know of any reason that it wouldn't work, but I don't want to advertise that it does until I get a 968 starter in my hands to confirm. Hint hint.
Old 08-18-2016, 01:47 PM
  #131
ideola
Former Vendor
ideola's Avatar
Which is why I only posted my experience and results, and not a dissertation espousing the benefits of these starters. I think the data speaks volume. I've only heard of a single anecdote of failure, as in the comments a few posts above.
Also, bear in mind, HiTorque starters are used in many many applications. So have a look online at the reputation for other makes and models, not just the 944. We try to do our due diligence before approaching manufacturers to make things for us, and I've found very few complaints anywhere with the HiTorque product.
Old 08-21-2016, 10:47 PM
  #132
Nathan J.
Nathan J.'s Avatar
If you get the gear reduction starter to work for 968 with manual transmission, I will be ready to buy in a heartbeat.
Old 08-21-2016, 11:20 PM
  #133
ideola
Former Vendor
ideola's Avatar
Someone send me a core!
Old 08-30-2016, 10:55 PM
  #134
touareg
touareg's Avatar
I just changed mine last fall, had to send the core back to get my $150 back
Far as I know they are ALL re manufactured now, would be nice to have a new option, that is lighter, better etc.
Post over on the 968 specific forum, I am sure someone has one there.
Old 08-31-2016, 02:33 AM
  #135
Arominus
Arominus's Avatar
is the 968 starter different? i'm using the stock late 944/turbo starter with my motor swap, however i'm using an S2 flywheel and bellhousing to make it work with the factory s2 TT and trans.
Quick Reply: It's On!!! Official Group Buy: Gear Reduction Starter
