Interesting... The 1987-1988 944S cars had a warning switch on the PS pumps that triggered a dash light if the fluid level dropped too much. Wonder if you have a gauge cluster out of a 944S.
Check engine light is below the air bag light on US and Canadian models. Do you have airbags? You should. If so the lack of an air bag light is puzzling too.
Easy way to check would be looking at the tachometer redline - 944S was 6800, 944S2 was 6400?.
Also that wire on the PS pump has shorted out and caused fire/wire damage to more than a few 944S, good idea to cut the wire and install an inline fuse with low amp rating there.
