If you have late style mounts, it is highly unlikely that the strut bearing would cause any side-to-side movement, as it is staked into the mount. Don't know about early style. As has been talked about before, it is better to look at wheel bearings and/or caster blocks.
I replaced my late strut mounts, but there was no side-to-side movement, the bearings had lost their seals and lubricant and were seized.
Originally Posted by mikemyers924s
I am also having this issue. Is my strut bearing not situated correctly in the upper perch or mount? Very confusing problem.
