Yet another wheel offset question...
I got myself 4 used 17" cup wheels part # 993.362.124.00 and was wondering what size spacers do I need if any? If I understand correctly older wheels have 23.3mm offset and new ones 52.3mm. Would I need a spacer with a width of the difference between the 2 offsets? I can't really get this offset thing yet.
Ok, here you go...
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=001274" target="_blank">Max rear tire width on 944T 951 </a>
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=15&t=001305" target="_blank">86 944 Wheel upgrade options</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=005808" target="_blank">17" wheel upgrade questions </a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=006158" target="_blank">Late wheels on an 86 951</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=001305" target="_blank">86 944 Wheel upgrades</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=001215" target="_blank">86 944 na - Turbo wheel</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=18&t=000144" target="_blank">'86 951 wheel upgrades</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=001277" target="_blank">Biggest, widest tires/wheels on 1987 944???</a> (has 18" Technical Service Bulletin)
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=20&t=000095" target="_blank">Wheel spacers for early offset</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=20&t=000116" target="_blank">'87 wheels on an '84</a>
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=18&t=000697" target="_blank">Will NEW 996TT 18" Twists fit '86 951 ? </a>
<a href="http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=001274" target="_blank">Will 993 rims fit on 951?</a>
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=002465" target="_blank">Wheels </a> (has 17" Technical Service Bulletin)
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=002201" target="_blank">Why are 18" wheels not recommended??</a>
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=15&t=005750" target="_blank">On the Road Again - Photos of the new wheels! </a> Photos of 17" 993 wheels on '86 951
Thanks a lot Danno, the links and the racerx website really helped. Still, just to make sure...
The rims are 17x7.5 and 17x9.5 [overall width] the backspaces are 6" and 7" respectively. Which give 57.15mm offsets. Since I'm sure I wasn't as precise as I could've been while measuring, I'll say this is quite close to the late model's 52.3mm offset. So, if I add a 29mm spacer the offset will be back at 23.3mm. Is all this correct or am I missing something?
