Paint prep checklist
Old 05-16-2008, 11:18 AM
V2Rocket
Rainman
V2Rocket's Avatar
Default Paint prep checklist
Alright, I'm mentally preparing myself for getting some new paint on my car. The crappy PO job is coming apart in places and there are plenty of scratches that need to be addressed. I'll be doing this over the summer and plan to do at least the prep work myself. I had a good experience having another car painted by a local Maaco but I may end up building a booth in my driveway and going at it myself.
Anyway, I just threw together this list of prep work for a good paintjob. I only am painting the exterior, not the engine bay, and it will be the original color, Mahogany Brown Metallic (LB8Z).
- Pull front valence/foglights/markers
- Pull front bumper/turn signals/pads
- Remove door seals inner/outer, mask doorway to paint doorsill
- Pull door handles
- Pull mirrors and mask the black part/glass
- Pull sunroof, remove interior hardware, mask the hole in roof
- Pull window scrapers, mask the windows
- Pull hatch/hatch carpets/rubber seals, mask interior of cargo area
- Pull rear bumper/flexible plastic pieces/pads/markers
- Remove taillights, mask holes
- Scrape off "PORSCHE" banner below license plate
- Remove license plates/brackets
- Remove gas door/flap/gascap, mask filler hole
- Remove antenna/944 badge/Porsche badge
- Remove rain rails
Then sand the bastard down to primer, give it another coat of primer, a few coats of paint, and eventually a clearcoat.
Two questions though:
1) Should I remove the quarter windows or just mask over them?
2) Anything else I should pull off the car before paint?
Old 05-16-2008, 11:29 AM
420WHP944
420WHP944's Avatar
Sounds like a plan! .... Yes you would be better to remove the quater windows for a better more pro job. One thing though...make sure you DONT sand the final coat of metallic before you put the clear on.
Hope it goes well for you!
Old 05-16-2008, 11:46 AM
harrisonrick
Captain Obvious
harrisonrick's Avatar
Sealer is a good idea when covering other paint jobs. It will prevent sinkage.
Also...when the door handles are gone, overspray can get into the cabin if there are ANY holes in the door panels...you might want to mask them too.
When my first 944 was painted...I stripped it apart...like you...even the door panels inside the car. I had no rubber for overspray to hit. the guy who painted it had a noob do some tinted primer...and he didn't mask the holes. let's just say there was a mad scramble and screaming when the painter saw the overspray misting into the cabin of my car....good thing I had stripped most of the carpet and seats out...the old steering wheel had a red tinge to it, but I swapped it with a Dino wheel...and the front windscreen had to be scraped with a razorblade. I got a free buffing after that fiasco.
Old 05-16-2008, 07:37 PM
V2Rocket
Rainman
V2Rocket's Avatar
For the door handles I'll just pull off the interior card and put tape on the inside of the doorskin so paint won't get through.
And what do you mean by "sinkage"?
Old 05-16-2008, 08:13 PM
rosco
rosco's Avatar
You dont have to sand it down to primer. But ,yes it is safer to do this.
Why wetsanding before clearcoat? I dont see any reasons to do this.
me @ making living with car painting
Old 05-16-2008, 08:30 PM
420WHP944
420WHP944's Avatar
Thats what I'm thinking and said 2 posts previous....DONT wetsand final base coat...
Old 05-16-2008, 09:06 PM
V2Rocket
Rainman
V2Rocket's Avatar
wetsanding crossed off to-do list lol.
Old 05-17-2008, 12:14 PM
V2Rocket
Rainman
V2Rocket's Avatar
One gallon of paint or two for a good deep paintjob?
Old 05-17-2008, 12:24 PM
apierce918
Addic
apierce918's Avatar
probably one, you will thin it with reducer so you will have more than 1 gallon of actual sprayable paint. i would also take your mirrors apart so you dont have to mask them, i made a little rack that held the 3 pieces and it worked out nice, i think i have paint pics during my prep somewhere to show how i did it
edit: gah, looks like i only have the after its painted pics had hard copies of prep somewhere, but i think they are gone forever
Old 05-17-2008, 12:41 PM
Marcquito
No, not Mosquito!
Marcquito's Avatar
Location: Gliese 581g | Monte-Carlo, Côte d’Azur, La Planète Terre
V2 Rocket,
Check out my thread: https://rennlist.com/forums/showthre...56#post5421656
It's already packed full of useful information due to painting. Also, I'm in the sanding process as we speak. Hopefully the car will be finished during this Summer. I'll be documenting everything from sanding, to booth building, what paint I used, to the final buff. I hope it helps you out.
Oh, and good luck!
Old 05-17-2008, 04:04 PM
V2Rocket
Rainman
V2Rocket's Avatar
Marc - I had it bookmarked the day you posted it
Old 02-08-2009, 03:21 PM
V2Rocket
Rainman
V2Rocket's Avatar
So what other chemicals will I want? I keep reading about "flex agents" for bumpers/valances etc, I guess that helps protect the paint when the parts, well, flex...
Also what is the purpose of reducer? Does it make the paint thinner and spray easier?
Old 02-08-2009, 07:03 PM
drift a 944
drift a 944's Avatar
Here's my paint thread with a bunch of pictures. As you can see, I did a color change and still didnt feel the need to go so far with removing a bunch of stuff and outdoing myself. Since you are painting the car the same color it already is, you really dont need to remove things like the tail lights and quarter windows, because the paint behind them will not be faded, chipped, scratched, or old looking. It would be worth it if your goal is a professional paint job, but since you are painting it in your driveway, how professional can it be?
https://rennlist.com/forums/924-931-...s-of-pics.html
What I used was 3 quarts of color (3/4ths gallon) and a bit over a quart of reducer. It varies though, because different paint types will have different mixing ratios. I bought a gallon of clearcoat, with a quart of reducer and a quart of hardner, and I was left over with plenty extra of these materials.
F18Rep
F18Rep's Avatar
Wait a minute, I thought we decided roller paint jobs was the way to go, maybe I dreamed that..... Bruce
Old 02-09-2009, 12:12 AM
DarylJ
DarylJ's Avatar
Get the flex agents if you can. I skipped them, because they only came in much larger quantities than I needed - I needed about 2 ounces and it came in a quart minimum.
Reducer is part of the sprayable paint formula. It will be in the spec sheet how much to use. But, yes....it makes it thinner. And affects how it dries (you can get reducers for various temperature ranges).
Quick Reply: Paint prep checklist
