wiring diagrams
Old 01-31-2008, 09:28 PM
db944
db944's Avatar
Default wiring diagrams
Ok, so what does the "KL.30", "KL.X", "KS 337" mean on the 944 wiring diagrams? I am trying to find the source of power coming to the wiper stalk.
Anybody know what this means?
thanks,
DB
Old 02-01-2008, 12:18 AM
Spidey944
Spidey944's Avatar
shoot me a PM and I'll print/fax you a different diagram if you want. Should be easier to read. I have never seen those designations b4.
Old 02-01-2008, 12:20 PM
db944
db944's Avatar
Here is an example of what I'm referring to in the shop manual wiring diagrams:
Anyone have a clue what this reference is ?
Old 02-01-2008, 12:31 PM
Spidey944
Spidey944's Avatar
My wiring diagram is much more simplified that this one. can I fax it to you?
Old 02-01-2008, 12:43 PM
Spidey944
Spidey944's Avatar
Here is what I get from my diagram.
When key is in ACC or RUN position, power comes from fuse #24 (30A) and goes into a Solid State module(relay?) it lookes like. The module is for the intermitant wiper controls.
From there it goes to the multi function stalk that turns your wipers on I do see that all of these things are grounded at the same source, G0116 brown wire on the left side of the firewall.
It is possible that the ignition switch portion that powers this perticular circuit is bad, but these kinda things are hard to diagnose without being right in front of it. HTH let me know if you want this faxed.
EDIT: I also see that this same ground goes to your washer sprayer pump, does this work?
Old 02-01-2008, 01:58 PM
StoogeMoe
StoogeMoe's Avatar
KL.30 is the power directly from the battery.
KL.X is the switched power when you have the ignition switch in the run position.
Old 02-01-2008, 03:25 PM
db944
db944's Avatar
That makes sense. Thanks for the explanation. (love your avatar by the way). Nyuck nyuck nyuck.
Quick Reply: wiring diagrams
