project: turbocharging 944 N/A the proper way
#301
Wow, that must be what, 3 straight days of driving one way? Crazy.
Heres another part for catalog. Found it today. Hydroboost from 964 Turbo
#302
Got a new block yesterday in Vienna, Austria. It came with bonus 944.104.310.2R head and everything else still attached to it.
Big thanks to user morghen.
#304
Ill strip the block and get it to machine shop this week. I hope all goes as planned this time.
Ive had luck with removing head studs, no thread harmed in the process
2.7 head appears to be in very good contidion.
#305
Block is free
#307
Thanks.
If everything goes as planned, engine should be assembled soon.
I took the head to machine shop for resurfacing and they measured it, turns out it is perfectly flat. No need to deck it, so I just cleaned the combustion chambers and test fit new 48mm 2.7 OE TRW intakes and new TRW 951 sodium exhaust valves. Now I need some new OE or aftermarket valve springs. Are there any spring manufacturers that make 951 valve springs that are stiffer than original?
#308
I have done quite a bit of work as of late looking at springs. I have found a combo that I think is going to work out really well. It uses a Pontiac V8 outer spring and a Ford inner spring. They work with the stock retainers but the spring cup is eliminated. At stock install height they have 140-145 lb seat pressure and allow for up to 0.550" lift. I am having everything verified now with my head guy and will be posting about it in the turbo forum soon.
#309
Nice. I might be interested in a set of those too.
#310
Double Good news today
1 Got a call, they say my block is ready for pick up.
2 Got two usps boxes with really nice contents delivered.
#311
This came in the boxes.
#314
Thanks.
I'll document and post a lot of pictures when I start assembling stuff..
#315
The Haltech Hall Effect sensor has been in production for a number of years and it has been a popular item due to it’s ability to be able to generate both home and trigger signals from the one sensor.
