Roll bar for 944 Cabriolet??
Old 04-26-2007, 07:00 PM
Fishey
Fishey's Avatar
I am 6ft but with a big upper body (I have a 74.5" reach for example) I would guess with a similar setup you would be alright. My seats are very low in my car and I barely make the 1" rule with a helmet on. As far as what I had to cut is the interior panels that house the rear speaker holes (I cut them as a square) It was a PITA to say the least but when I am at home I will post up a picture of the cutout panels.
Old 04-26-2007, 07:31 PM
Lumbergs Lackey....MmmmKay
Lumbergs Lackey....MmmmKay's Avatar
No offense but man that roll bar is UGLY, and I mean FUGLY. Can someone make something that at least looks decent.
Old 04-26-2007, 08:06 PM
Dan Shea
Dan Shea's Avatar
Originally Posted by Maciek
Also, what seats are you running to get the adequate clearance and how tall are you (if you don't mind).
I think he has the corbeau forza seats. Atleast thats what is in the picture.
Old 04-26-2007, 11:54 PM
Fishey
Fishey's Avatar
When I build my car to look pretty I will let you know. Also, it looks almost identical to pretty much every boltin cage known to man. Its actually identical to the rollbars used in Rx7's.
Old 04-27-2007, 01:53 AM
V2Rocket
Rainman
V2Rocket's Avatar
You could make it chrome :P
I seriously doubt the track-only guys are worrying about how their interiors look...lol (what interior?)
Old 04-27-2007, 09:31 AM
adrian_jaye
adrian_jaye's Avatar
Under "normal" circumstances the windscreen, acts as the ROLLBAR,
This is one reason that a 944cab is not simply a chopped 944 coupe !
Had some fairly indepth discussions with Porsche techs a while ago about this and other differances on the s2 cab.
Of course if your head is TALLER than the windscreen then you have a possible problem.
again I say normal circumstances, I dont know about racing /track day issues.
Mind you, I've seen track day pics of guys in an s2cab, with a helmet and top down !
Originally Posted by xsboost90
you should be able to run a DE in your car w/o a rollbar, just need to leave the top up.
check the rules out on www.pca.org should be on there or somewhere w/ the pcna if its a porsche event. If you had the top off, you would need a rollcage, or if you were racing.
Old 04-27-2007, 10:02 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
If you look at the pics in this auction, it is installed in a 944 cabriolet:
Click Here
Old 04-27-2007, 10:06 AM
fpena944
fpena944's Avatar
Click Here
That doesn't look like a 944 Cab. Unless the top was entirely removed?
Old 04-27-2007, 10:28 AM
jsaindc
jsaindc's Avatar
It actualy looks like a 928 converted to a cab.
Old 04-27-2007, 12:14 PM
Fishey
Fishey's Avatar
There are are a ton of differences between a coupe and cabriolet. The Tub of the cabriolet is very different from that of a coupe. The Rear wheel wells are a perfect example of this. The Floor pan in the middle of the car is also very different then the coupe in that it has 2 modified floor pans welded to each other. This also allows the front unibody frame to be reinforced from side to side (Under body Difference). The entire underbody of of the car is more aerodynamic (has paneling compared to a rough floor pan bottom). The Windscreen comes into the body in a different fashion allowing it to be much stronger as well as reinforcing the body. The windscreen is also shorter in overall height and also raked to a different angle. The 120# real difference between the two is offset even more when you remove the 40# weight in the right rear. (It does nothing except reduce very small vibrations and throw off your corner balance) The cabriolet also has a plastic gas door and I think the coupes are steel.
That being said if you roll over a cabriolet its going to crush down. I have pictures somewhere of one we parted at the shop that had rolled and somehow the guy walked away unhurt but the window frame was flat against the top of the door.
Old 04-27-2007, 12:20 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
It's a 928 - look at the door handles.
Old 04-27-2007, 02:02 PM
JEC_31
JEC_31's Avatar
Michelle is correct.
Carl (928 Motorsports) had a very nice early 928 cabriolet conversion in his collection until recently. IIRC he sold it because it wasn't being used and enjoyed properly, he is too busy wrenching, racing (Pike's Peak this year!!!!!), and selling cool 928 high-performance products.
~~~~~~~~~~back on topic~~~~~~~~~~
What's that line from the magazine ad... "Das Sport rollbars - AKA Thank God!!!" with the pic of the wide-eyed driver upside down.
Old 01-03-2013, 01:08 AM
Zuffenhausener
Zuffenhausener's Avatar
Bringing an old thread back to life here. My question is to anyone with roll bars installed in their 944S2. Which model seats have you found that place you low enough to allow you to pass the broom stick helmet clearance test? And does anyone know for sure what the broom stick test actually specifies? e.g. Stick must clear helmet, or stick must clear with 1" to spare, or 2" to spare? I have heard conflicting accounts on this point. Thanks!
Quick Reply: Roll bar for 944 Cabriolet??
