power steering rack plug
got underneath to locate my PS leak, and found it dripping from a little plastic cap on the drivers side of the rack. it looked like a plug so iu tried to tighten it but it just spun, then i loosened it and it broke off, but left the plug in the hole. it was dripping like crazy so i put some seal-all on it and it seems to have stopped. is it safe with the seal all there? is this a drain plug or something? where can i get a new one?
There is a black rubber plug at the base of the control tower. Mine basically did the same thing when I tried to remove it while rebuilding my rack. I got my replacement from the dealer. I think it was about $2.
It's actually an inspection plug that is used to center your rack during an alignment.
Originally Posted by GlenL
That plug isn't supposed to see any pressurized fluid. If it's coming out strongly then there's a problem somewhere else. Some racks I've seen have just a press-in plug. I'll predict that if you seal that up good it'll "stop" for a while until it starts flowing out the tie rod boots.
Glen is right, but I would say there should be no fluid behind that plug at all. The only way for fluid to get there is due to a leaking seal - sorry. If you're handy, lucky and determined, you can fix it for about $40, if not then much more $
Bruce
Bruce
Bruce
Bruce
