Rear seat delete begun-not the usual method
Hey Man
Rear seat delete/package tray almost finished- a few pics
Well I started stripping everything for the project yesterday and have all my dimensions down. Many people have done this with just removal of the hinged upper section, seat bottom, and adding carpet. My project will use the stripped upper section with a carpeted front to attach my amps. The old seat area will have a built up front like the 968 Cab w/ rear seat delete with carpeted bottom. I really want secure storage for my cameras and such and with the upper section down no one can see the amps. I have several panels of anodized aluminum with large 3/4" cooling holes to insert in the vertical section from the floor up to keep the amps cool if the rear section is folded down. I plan to do a photo history if I find time.. The sub goes into the RR cubby with mid bass speakers replacing the rear 4"x6" speakers. I think this is going to be a pretty enjoyable project so far but we all know how that goes. Just thought I would share because I cut my leg badly about an hour ago and have to call it quits, but my fingers still work
BTW: Xylene will remove any adhesive Porsche used and dissolve foam rubber that sticks to metal or wood.
Hey Man
Originally Posted by Andial951
pics? Are you documenting the install?
Originally Posted by KuHL 951
The way I look at it, only Bavarian elves can sit back there anyway so I'm going for broke and making something that suits my needs.
Best of luck to you, I'm looking forward to pictures and continued documentation of the fabrication and installation.
I don't like the rear seatbacks stll being there so much, but.... Just thought you'd like to see it- this was a guy named Jeremy's, who used to be on the list- was very original- he had 968 door panels & several other mods in a 944NA.
Hey Man
Originally Posted by Robby
How would something like this work...?
I like that but don't think I'll be putting speakers in that spot. I'm still trying to match the carpet from a good source and looking for a good sound deadener for under the seat area.. Looks like the owner on that one did a great job, looks very professional. So far stripping the folding section to bare wood and hardware has been the hardest part. It goes beyond just pulling off foam and leather. The hardware at the catches has to be disconnected to remove the trim rings on the push button releases, what a pain...almost as much fun as a door handle! I also have to extend the depth of the folding section; once the lower seat is removed there's a 4" gap between the rear deck and rear of the folded seat back. I'll keep a photo record of anything that might help others
I recently finished this subwoofer box for someone, although it's not finished in this picture. Once installed and carpeted it's the same height as the rear deck. It could just as easily be made to have two locking compartments.
Try www.stockinteriors.com for the carpet. They sell it by the yard and it's a very close match.
Hey Man
Did you forget the picture? Thanks for the carpet link I'll check it out later.
I didn't order the carpet, but i did get a sample of the black cut pile. It seemed a slight bit longer than what was in my car, but then again that carpet it 20 y/o. I don't think it's anything you'd notice unless you were inches away from it. The box is going into a car with a linen interior so he is going to get a sample to match it and then carpet it himself.
Hey Man
Originally Posted by Dr.Porsche
Thanks. Thinking of dpoing the delete. Not sure , as the bottom section is supposed to be very hard to remove.
The bottom section comes off really easy, took me about 5 minutes. Stripping the top back section is another story though.
