BMW Oil cooler line repair- how bad? 325i
Old 04-04-2006, 08:09 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Default BMW Oil cooler line repair- how bad? 325i
Subject: 1990 BMW 325i 130k miles.
diagnosis: needs both oil cooler lines.
also: PM due- timing belt, wate rpump front engine seals. Otherwise a solid mechanical vehicle.
I havent worked on BMW's, does (should) the engine come out for this ? how difficult? how much?
I know this is a Porsche forum, but I know a lot of you also work on bimmers.
I'm looking at an alternate daily and need a grip on how much this would cost to fix.
Old 04-04-2006, 09:11 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Good timing on this one. I just pulled the oil cooler on my 91 325 iX two weeks ago. No problems at all. You can get to from underneath by removing the splashpan and removing two mounting bolts. I was able to get mine out without removing the front fascia but it took a bit of maneuvering. I think your front fascia should be similar on the 325is. Be ready to make a mess when you disconnect the hoses. Good Luck
Old 04-04-2006, 11:51 AM
Legoland951
Legoland951's Avatar
Your timing belt will need a very thin wrench (special tool for BMW) to remove the fan and fan clutch. Its been a while since I did one but the rest is pretty straight forward as compared to a 944.
Old 04-04-2006, 12:06 PM
Fishey
Fishey's Avatar
I don't know about early 325's but the later ones (E36) use timing chains.
Old 04-04-2006, 12:22 PM
AZS2
AZS2's Avatar
Depends on the clutch doesn't it? I think there is 2 different fan clutches randomly used. You can get a bicycle wrench made by Park Tools for that job too.
Old 04-04-2006, 12:28 PM
85944na
85944na's Avatar
the e30 has a timing belt, the water pump and belt are very inexpensive. I also replaced a tensioner, the cam seal is really easy to do once you're in there. I don't know what the oil cooler lines run, but without those you ought to be around 100$ in parts.
Old 04-04-2006, 12:38 PM
KuHL 951
Hey Man
KuHL 951's Avatar
If he has a 90 325 he has the newer fan clutch and doesn't need the slim wrench. Four bolts on the front of the clutch and off it comes. If you are planning on keeping the car you should definitely buy the Bentley repair book. Another good source of routine DIY BMW info is: http://www.bimmerdiy.com/
For parts numbers and dealer price estimates I like to use: http://www.realoem.com/bmw/
The E30 belt job is simpler but it takes quite awhile to get to all the parts. A Conti belt and tensioner runs about $22.
Old 04-04-2006, 01:51 PM
GlenL
GlenL's Avatar
FWIW - I've had my 928 oil hoses repaired at a local Pirtek franchise. They re-use the fittings and put in a new hose.
After two years one seemed like it was maybe oozing at one fitting and twisted too easily at the other. Not sure if there was a problem but had the hose replaced anyways.
The real trick is the bottom line: Under $20 to have a hose renewed.
Old 04-04-2006, 08:01 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Awesome. I KNEW I could count on Rennlist! Thanks all!
Quick Reply: BMW Oil cooler line repair- how bad? 325i
