exclamation mark....what does it mean?
I have an 89 944. The exclamation light in the center of the instrument cluster has been lit up ever since i got the car. the car had front-end damage before i restored it. What does the exclamation mark mean.? It bugs me while im driving, i need it to go away!!!
thanks.
thanks.
1 Post
I just use the " Massive amounts of smoke coming from under hood " warning before I really act on a problem
could be a brake pad sensor, low gas stuck... it's probably a " Some sort of gauge is out of spec "...
Like I stated, I am only used to the early ones ( the good ones ), but I will try to look it up if noone chimes in before hand...
Glad to see another SD/LA area person.
Don
Don
Often times the sensor gets bent down and the light will still be lit with the handbrake 'all the way down.' You can simply bend it up a bit and fix the problem (if thats what it is).
thanks. i will check for all these things in the morning.
and "Don 944 LA" im in fullerton mon-thur and in SD for the weekends. A good drive from school (CSUF) when theres no traffic.
Campeck Rulez
list of [__!__] problems.
oil pressure. handbrake. low brake floid. low oil level. airbag. brake pad sensor. seatbelt?
with front end damage i would geuss airbag. you sure ther aren't ANY other lights on with it?
Nerd Herder
Originally Posted by Dilberto
It means "Achtung, Amerikaner
Us "Old dash" guys have no such problem.
Spell Checker
I have not found anything to fix the problem yet. I will try changing/checking the dash bulbs to see if any are out, because no other lights are displayed beside the exclamation of death.
