stupid question.. TPS
Old 08-07-2005, 12:56 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Default stupid question.. TPS
OK, my idle is running high when warm. (like 2000/ 2100 rpm)
at the risk of sounding ignorant- here goes-
Where is the TPS? (throttle position sensor) and how can it be rebuilt?
PET is no help.
I feel like an idiot.
Old 08-07-2005, 12:59 AM
bloodraven
bloodraven's Avatar
its okay, i am in the same boat...lol
Old 08-07-2005, 01:02 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
I know I forgot this.. from years ago. havent had the need so my knowledge evaporated..
No worry blood- i got your back brother. I'll take the heat here- It took nutz for me to even post this here.
I should know this.
Old 08-07-2005, 02:04 AM
mavfan
mavfan's Avatar
the tps is located directly under the carburator, hopefully u know where this is! lol jk
Old 08-07-2005, 02:09 AM
mavfan
mavfan's Avatar
oh and also to check it or rebuild it, no real clue, but i'd get a voltage meter. the white wire should be at 4.7-5.0, the black wire will be at 0 and the brown is just the ground i believe, or maybe its switched at its the brown that should be at 0 and the black is the ground, that makes more sense. to test to see if they are responding correctly (btw the key should be in the on possition, u dont need the car running though) put the pedal down to the floor, and their numbers should change to the exact opposite of the brown being at 4.7-5.0 and the white being at 0. if they do this correctly then ur tps is working correctly i believe, somebody should check me on that though. it would probably be something else. hope this helps
Chris_924s
Nerd Herder
Chris_924s's Avatar
Carb?? now I'm really confused.... Damn.
Back to my red beans and rice with Tabasco from Redfish...
Old 08-07-2005, 02:35 AM
7thStranger
7thStranger's Avatar
dude, it's the little black thing under the throttle,
disconnect the throttle body from the the air box and turn it over.
I think clarks garage has a write up on testing it.
Old 08-07-2005, 03:06 AM
mavfan
mavfan's Avatar
i'm sorry, but wow...lol just look at the top of the engine in the very center, its between the bent black tube (like a C shakpe) and intake manifold (the thing that goes from one tube, to 4 smaller tubes) thats where the carb is, ur trottle cable connects to it, yanno ur gas petal line? lol and then the tps is located right beneath it!
Old 08-07-2005, 03:08 AM
TRWright
TRWright's Avatar
Carb? Did you just say carb?
Old 08-07-2005, 03:10 AM
Sam I am
or Sam O
Sam I am's Avatar
black box under TB
Old 08-07-2005, 03:11 AM
Campeck
Campeck Rulez
Campeck's Avatar
mavfan....carb?!
these cars are fuel injected.....
your a funny guy!
Old 08-07-2005, 03:30 AM
mavfan
mavfan's Avatar
man essentially the same thing. meh, thats just what i call it imo... ok now i feel really lame lol
throttle body works just fine!!!
Old 08-07-2005, 03:33 AM
mavfan
mavfan's Avatar
oh and i REALLY dont mean to be a funny guy. i wish i was more boring around here! lol
Old 08-07-2005, 06:23 AM
Luis de Prat
Luis de Prat's Avatar
Theoretically, it can't be rebuilt and you should fit a new one for around $80.
However, our good friend Bruce at arnnworx.com has figured out a way to rebuild it and has the procedure explained somewhere on his website:
http://www.arnnworx.com/tps-repair.htm
Have fun getting the throttle body off!
Old 08-07-2005, 11:02 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Thanks Luis- exactly what I was looking for-
BTW- and it's right under the carb!! j/k.
Quick Reply: stupid question.. TPS
