Oil dipstick smells like gas
I just changed my oil with Mobil 1 15W-50. For the 1st time, I smelled the oil dipstick and I noticed there was a gasoline odor to it. Is this normal? I hope I dont have gasoline in my oil. I heard that if there was gasonline in the oil, the gas would drip off the dipstick when taken out, but the dipstick does not drip of any liquid.
Nerd Herder
Run it longer and allow the gas to evaporate out of the oil/. If the rings have wear, the fuel will leak onto the pistons and pool, dripping into the oil. If you get it up to temp and have a "spirited run" and it still smells fuel... maybe a leaky injector.
Has it been sitting for a while?
Nerd Herder
Originally Posted by Techno Duck
Just to add, i believe fuel mixed with oil can be a symptom of a bad fuel pressure dampener.
I was going for the "not started and run in a while" angle.
