Questions about Octane for NA 944
Manual says to use a minimum of 90 octane, flap over gas cap says fill with 91.
Premium here in Phoenix at most sites is 91, some have 92 or 93. I went to fill up the other day and the site was out of 91....luckily, I found some at the next station...but it started me thinking....
Is there any harm in running a lower octane in an emergency? I know lower performance/knocking/pinging will be an issue, but does it actually hurt the engine?
I have access to 100 octane racing fuel......Will I burn up the engine if I run a tank of 100 octane through it? Is there any benefit running a higher octane than 91?
Just curious,
89AZ944
Just curious,
89AZ944
For a naturally aspirated stock car, running higher octane wont do a thing. There will be no direct harm running lower grade fuel, however; your car wont run very well.
Of course...theres the trickle down affect: your engine starts to vibrate, wearing your motor mounts quicker...
Ok, thats really stupid. Either way, running lower octane for short periods of time wont do anything to your car.
In my 84 I run 87 octane and it works just fine.
HOWEVER you have an 89 motor. I am pretty sure they upped the compression ratio so best to use 91. I run 91 in my 944-spec car straight from the pump has worked fine. I did try 110 leaded race fuel once. Just made my wallet lighter. Never again. I also run standard 91 in my 944 Turbo S. No problems.
The 944 turbo has knock sensor for those "emergencies". Performance was not so good however. Worst case is you can detonate and blow a head gasket. I am not sure if the 89 NA has a knock sensor. It really should not be hard to find 91 around town. If in an emergency throw in the best you have and be gentle. Don't accel hard or she high or low RPM with any sort of load. Put in 91 as soon as you can. I would think that short of the gas issue we had last year it would be easy to get 91.
From what I remember, octane is just a measure of flamability, higher octane meaning less flamable. High compression engines need higher octane, so the gas can resist igniting early. Lower compression engines can use lower octane. That's why accords are OK with 87 and benzes need 91 - the compression ratios. That's what I remember, anyway. So it's just based on your current compression ratio. If you use too low of an octane, you'll get detonation. Not sure about too high of an octane - might make it run rough due to lack of ignition or something, I guess.
Check to see if it says 91 RON or 91 MON, there is a difference.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Originally Posted by Serge944
For a naturally aspirated stock car, running higher octane wont do a thing. . .
For our US-spec n/a cars (that have considerably lower c/r's of 9.5-ish:1 versus the Euro 10.5-ish:1 - the exact c/r's vary a bit by year) there will be no serious problem in running 87 or probably even a bit lower octane ratings. In other words the engine will RUN on lower octane, it just runs with more and more stress on components - eventually you'd get to a point where the engine just wouldn't run on the fuel, but that would be a point far lower than 87 octane.
However, since higher ratings do give you more efficient operation, smoother burn, lower CHTs, etc. I recommend it whenever possible. Running higher will probably not dyno you any more horsepower (this is one thing I intend to check at the dyno day next week on the n/a car), but it will be "nicer" to your engine in the long run, put less stress on components and probably show benefits over very many cycles of use.
Originally Posted by Porsche-O-Phile
Read the "Gasoline FAQ" on the Racer-X website. Lots of good information there. FWIW higher octane WILL help an n/a car - just ask any hot rodder that's running 13:1 compression!
Running 91 octane in a low compression N/A engine only has one effect, a lighter wallet.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
The 944 NA can run on gas above 87 w/out any pinging issues. I ran 87 in my 84 one time and it pinged; 89 octane ran with no problems. Today I use 91 because I feel I get the best economy out of this gas.
I run 87 octane in my car. Never has given me any problems. The 89 motor will be different. US octane ratings are also different than European ratings. Check what the manual says (RON or MON) and what the pump says. The ones around here, IIRC, are (RON+MON)/2, and the manual/ gas door is in RON.
Fuse 24 Assassin
Fuse 24 Assassin
Originally Posted by iloveporsches
Huh? How do you get the best economy out of paying more for something you don't need?
Nerd Herder
88 924S, higher compression- I will always run premium. I get midgrade if I'm light on cash and need gas.
I have noticed much less ZOOM when I put regular unleaded in during my "I'll see if there is a difference" phase.
I do not notice any knock, but degredation in performance and mileage is definetly present with regular.
FWIW- every 4 months I do run a tank with Techron thru it. She likes the Techron additive with premium!! Zoom zoom! Much quicker acceleration and throttle response afterwards.
However, since higher ratings do give you more efficient operation, smoother burn, lower CHTs, etc....
...but it will be "nicer" to your engine in the long run, put less stress on components and probably show benefits over very many cycles of use.
Originally Posted by 88BlueTSiQuest
But it's based solely on compression. The higher the compression of the car, the higher the combustion chamber temps are, the higher the chances of detonation are.
Higher octane ratings (AKI) are useful when building/tuning an engine. Higher AKI fuels expand the envelop of things that will improve performance without causing detonation with that fuel. This includes ignition advance, higher compression, high boost pressures, increased volumetric efficiency, etc.
MY 88 and 89 cars had a substancial bump in the compression ratio (up to 10.2 I think). On my old 88 n/a, it would detonate on 87 and 89.
For your 89 car, I would highly suggest 91 octane. 83-87s seem to do fine on 87 octane.
