Sickening knocking noise from head... have sound file, tried everything
Okay, so I finish my 4th oil pan gasket, do the oil cooler seals, koni conversion, control arms, ps rack, etc... I put the 951 back together after it sitting 5 weeks or so, and get this horrific knocking sound:
Wav file (1.2mb):
Sickening Knocking
http://www.geocities.com/roco1669/roco16.wav
Quicktime MOV (poor sound, 450kb)
Movie
http://www.geocities.com/roco1669/roco16.mov
(you may have to copy+paste into your browser window, a Geocities thing)
When the car was first started, it was fine for about 3 sec or so, then intermittent knocking, then constant knocking. Since then, the knocking has paused only momentarily if I blip the throttle (as heard in the sound file). The noise is definitely coming from the top of the motor, not the pan. It sounds roughly from the 2-3 intake runner.
So, after reading 30 or so posts in the archives about similar noises, these are the brainstormed possibilities:
1. Rod Bearings (unlikely, changed them 6k ago)
2. Dry Lifters
3. Pre-ignition, 'detonation' or 'knock'
4. Something fallen into the engine during reassembly
5. Wrist pin slop
6. Fuel Pressure/Injector problem
And here's what I have checked out as being a-ok by me:
-Timing. The car is in time, no problem
-Distributor/rotor. I increased my likelihood of arthritis again in taking that assembly apart. All was normal, tight...
-Oil pressure. Steady 4.5 bar at ~cold idle
-Compression. Quasi normal for my car: 133, 135, 130, 130
-Mechanical binding. Turned the motor over by hand, no problem
-Drained the oil. ZERO metal flakes
-Opened the camhousing holes and dripped ATF on the lifters/followers and cam lobes, no change
-Injectors are firing. Pulled the fuel rail and turned the car over to confirm all injectors are firing, and about the same
Any help is appreciated.
-Robert
Wav file (1.2mb):
Sickening Knocking
Movie
2. Dry Lifters
5. Wrist pin slop
-Robert
I'm sorry you are having trouble, Roco. My '86 Turbo is also knocking quite loudly, and it is emanating from the head. I tried to download your files, but your bandwidth has been temporarily exceeded. I'll try again later.
Robert:
Use a mechanics stethoscope or even a long screwdriver to try and pinpoint the location of the noise. It could be a collapsed lifter, wrist pin, piston, or something else. Compression seems even enough.
Thanks guys,
Alternate URLs for the movie and sound file:
http://www.geocities.com/roco16669/roco16.mov
http://www.geocities.com/roco16669/roco16.wav
Copy+Paste them into your address bar if they come up w/ the 404 Error (dont ask why).
Other thoughts:
Would cylinder compression vary if a lifter is siezed/ collapsed?
Cruise- I tried the stethoscope test with a long 1/2" breaker bar... I couldnt make much of it, other than center camhousing/head.
I'm going to take off the intake manifold tonight and verify the intake valves are opening/closing ok, as well as run some cleaner through the injectors. If no change, the I guess I have to pull the cam housing and check for bad lifters.
Cwigg666 - That means I'm going to need our timing tool back to re-install everything...-thx
Thanks for everything guys,
-Robert
Other thoughts:
-Robert
I had the same noise happen to my turbo after letting it sit a few weeks. Really bad knock. I was able to isolate to the #4 exhaust valve lifter. Anyway, from sitting, it just bled down and couldn't regain pressure while running. I pulled the DME relay and cranked over the motor until I had good oil pressure (15 to 20 sec.). The lifter pumped back up and was fine. 8 months later all is well. Give it a shot.
Jeremy-
I read what had happened to your car in one of the archives. I really hope what is happening to me is from the same cause, but since reassembly the car has run a total of about 3-4 minutes, and maybe 40+ sec or so from starter only (compression testing)... all of this to no effect. I also have good oil pressure from the get-go. Did you ever replace the lifter? Was there any damage to it or the cam?
Chris-
I get off work around 6-7ish. Will be pulling the cam housing tonight, so if you want to stop by anytime after 7, that's awesome. Pretty heart-breaking noise, eh?
Chris-
[QUOTE=roco16]Jeremy-
Roco,
I ran mine several times for about 20 minutes tracking down the problem. Perfect oil pressure, just a solid knocking sound. Once I determined it wasn't a rod knock, I wasn't concerned with running it. I never had to replace the lifter or remove the cam tower. All it took was a good turn over cycle to get the oil pressure up through the motor. Once I saw good oil pressure on my gauge while cranking, I went another 10 seconds or so. Once I started the car the knock was gone. All is well now. Let us know how it works out.
Roco,
Nerd Herder
My heart just dropped when I hear the wavfile.. I just hope it's a simple oil pressure problem.
I wouldnt wish that noise on anyone.
I think pulling the cam tower is a good idea.
The following is just a datapoint...
I started up the car for the first time after the rebuild and tried to hold it to around 2000rpm...valvetrain was real noisy.
I shut the car off after it warmed up, later in the day I started it up and took it for a drive...lifters were quiet as soon as the car started. It didnt take very long for it to catch. The engine had 2 bar oil pressure prior to starting the first time.
It could be something as stupid as a failed exhaust manifod gasket. My jeep broke an exhaust maniford stud and it makes a hell of a mechanical racket. I was told by various experts that it was piston slap, broken oil pump, rod bearings, then I took a close look...
