Gas Leaking around Fuel Door
After a DE this past weekend I noticed that I had a lot of gas coming out from teh fuel cap area and running off the side of the car. I have also noticed that there is a gas smell in the cabin now. I have read the archives about gas smell in the cabin and looked at where the drain hoses come together and everything looks fine. Anyone experienced this problem and/or have a fix out there. I would think that since there is gas coming out of the car, that something with the cap or lines around the filler cap would be bad. Just need some help with someone who may have dealt with this before. TIA.
TJ
TJ
Nerd Herder
Was the tank VERY full and a hard right turn involved? That's enough for upsplash thru the filler tube to occur.. If not see the above fixes.
There is also a more difficult problem to fix there.
I had that issue on my race car. Well new o-rings failed to solve it. It turned out there is a flapper door inside the filler neck. Attached to the door is small round plastic 1/2 bubble that acts as a float to help close the filler door when fuel hits it. This bubble broke off and feel into the tank. It's pressese in the tank cause other issues, but the lack of bubble mean the flapper door did not close. Well my neck leaked fuel. It seems that the o-ring could not stop the fuel. I replaced the part of the filler neck and it has not leaked since. Seems that most of the fuel is held back by this flapper door and what gets by is sealed by the o-ring on the cap.
Hey Man
This sounds like probable areas to attack. I can hear a hissing/vaccum leak sometimes when I get home. I think I need to take a look at that flapper to see if it is bent back. Thanks everyone.
It is a race car and I only drove it with window's open. Never any fuel smell, but I am not sure that there would not have been if it were a street car.
No need to drop the tank, but you do need access to the filler neck. You will need to get unter the side carpet to access the black metal cover panel.
See pic below.
See pic below.
Hey Man
Great, I was hoping I could do it without a tank drop. I'm also suspicious of the 3" dia. gasket for the sending unit under that fabric cover in the photo. Brad-Cam had a leak here and found out it was a common source of fumes also, he gave me a gasket so I'll do both pieces at the same time just in case. Thanks again for the help, I'll post back if it solves the problem.
