headlights won't go down
Old 12-22-2003, 12:06 PM
erics944
erics944's Avatar
Question headlights won't go down
I just bought my first Porsche, a 1986 944n/a with 56,000 miles. The headlights pop up and work fine, but when I turn them off they don't go down. Any suggestions on what this could be and how to fix it. Also, any suggestions on tune ups i can do this winter?
Old 12-22-2003, 12:25 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Welcome..
Headlights wont go down at all? You may want to look for some obstruction in the headlight bucket. pull the power plug to the headlight motor and hand turn the **** to see if the complete headlight range is OK during up/ down rotation.
Tune up... a complete one including plugs, wires, airfilter, oil change etc if you dont know when it was done last.
If I dont say Belts someone's gonna hit me..
Timing and Balance belts if you dont have dated receipts of when they were last done.
Old 12-22-2003, 12:27 PM
icat
icat's Avatar
I'd start with cleaning the relay. Usually when the relay is dirty the lights just cycle up and down, up and down, up and down, up and... you get the idea. Most of us call that the Herbie effect. Anyway, the relay is a small square device (like a fat lighter) that's near the headlight motor (can't recall if it's on the motor or not, but I think it is). Unplug and then toss and replace (not a very expensive part) or you can pry the unit apart and clean the contacts.
Old 12-22-2003, 12:55 PM
HY M8NC
HY M8NC's Avatar
I agree with the relay. If you are looking down at the headlight motor, the left side is a rubber boot/cover. Pull that boot off, and the relay is right on top-usually it is white. I think they are around $10.
There was a post in here (search) that described opening up the relay. I've never done it, but it seemed easy enough.
Congratulations on the purchase-and welcome to the list.
Old 12-22-2003, 03:17 PM
UDPride
Thinking outside da' bun...
UDPride's Avatar
I believe theres a manual crank for the headlights just inside the hood. Like a big fat dial. Just in case you want to lower them before you get em fixed.
I kind of like the single headlight pop-up look myself. A lot of guys driving 88 Pontiac Trans Ams seem to enjoy that look.
Old 12-22-2003, 07:39 PM
JCNNJC
JCNNJC's Avatar
to lower lights remove the rubber boot on top of the headlight motor and turn it, you also can lube the linkage, I think there is a couple of places near each light.
Good Luck
Old 12-22-2003, 07:44 PM
SoCal Driver
SoCal Driver's Avatar
Be careful when using the manual ****. Somtimes the head lights will take off and close on their own. Keep track of where you put your fingers!!!
56k miles? Bet that is one sweat car. Did you get the service history with it?
How are the belts?
Old 12-22-2003, 07:59 PM
erics944
erics944's Avatar
Thanks everyone! I just pulled the relay off the headlight motor. I am going to get a new one and try that.
The car needs some TLC. Some small chips on the front and a small spot of surface rust i need to sand and touch up. The leather is perfect, no cracks in the dash. I have the history back to around 2000. A lot of the hoses have been changed. I would have to go back and check to see if the timing belt was changed.
I just got my insurance cards in the mail today! Going to get the plates tomorrow!!!
Old 12-22-2003, 08:05 PM
SoCal Driver
If you have no reliable history of the timing and balance belts being replaced do it now!
If you loose the timing belt it will bend the valves. A $1,200 hit if a shop repairs it. A $500 hit if you do most of the labor.
Worry about the paint chips later.
Old 12-22-2003, 09:07 PM
erics944
erics944's Avatar
Just looked back through the history I have and the timing belt was changed back in July 2000. They had a lot of work done in the last few years. So thats good....
Old 12-22-2003, 09:27 PM
SeaCay
Thefu
SeaCay's Avatar
July 2000? I would change the belt if I were you...
Old 12-22-2003, 11:03 PM
SoCal Driver
Yeap. Three years or 30,000 miles to be safe. No kidding!
Old 12-22-2003, 11:38 PM
RMills944
RMills944's Avatar
something simple - if they try to go down, but can't it may be the plastic around the headlight is on wrong. I had this happen in mine when I replaced the headlights. For this,, just take the plastic piece off (1 screw) and the headlight cover (3 screws) and make sure the plastic piece on the front is on okay (it must lign up just right). If they just won't move at all, and they aren't part way down, then ignore this.
Old 12-22-2003, 11:46 PM
adie
adie's Avatar
3 years or 30,000 miles (I guess that equals 10,000 miles a year) so a 1986 car has 17 years or 170,000 miles of wear on it, if thats teh case no bother looking for a low milage one are you sure there's not 156,000 miles on it.
Out of interest what is the going rate for the belts to be changed, not exact price but a close approx for belts and labour. Seems like the share prices are dropping and some needs to keep on boosing there stock options.
P.S. happy Holidays to all, if you couldn't tell, the only christmas spirit I have at the moment is in a big glass and it's called Glenfiddich.
Old 12-23-2003, 12:11 AM
SoCal Driver
I see Ryan is getting this thread back on topic. OK.
Under the plate that the relay mounts to are several contacts that tell the relay where to park the headlights. Kind of the same way the windshield wipers park. The head lights have two positions. Could be that these contacts and the circular tracks they ride on are dirty/corroded.
A worse case would be the large spur gear is worn in the up position and is locking up on the worm gear.
Quick Reply: headlights won't go down
