944S2 3.0 16V engine plus some other things.
Going a different direction with my S2 and no longer need the engine. It has about 105,000 miles on it, great oil pressure, and timing belt,water pump, chain tensioner pad, and aux belt done in the last 10000 miles.
2600 OBO
I also have a homebrew intake as well, it does not fit under the factory hood, you'll need a bump or vent to fit it. Also needs tapped vacuum lines. But it does sit high enough for a 6662 turbo to fit nicely.
asking 200.
944s2 homebrew 3" v band exhaust. Will include y pipe to header, I'll have to get some pictures but it is a mild steel system so it corroded and has alot of surface rust. But it sounded good (loud though) and uses factory hangers.
200.
will ship on everything at buyers expense.
Thanks,
-Austin
2600 OBO
asking 200.
200.
Thanks,
-Austin
