1988 924s dme ECU help - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 02-18-2017, 09:17 PM   #1
cxm
New User
Default 1988 924s dme ECU help
She has fuel pumping to the rail, spark, will run on starting fluid, but noid light shows no power at the fuel injectors.
Put in new DME relay, opened up dme/ecu computer, looked for bad solder joints, no change.
I would like to buy or borrow a new ECU to make sure that is not the problem.
I did just buy a 944 ECU, but it has three rows of pins and does not fit.
I will pay for your time, or the part, or whatever...if you can use the 944 computer, great.
I am in West Milford, NJ...
Need some help here, getting frustrated!
Love the car, want to drive it!
cxm is offline   Reply With Quote
Old 03-13-2017, 06:28 PM   #2
dp951
dp951's Avatar
Default David pagan 944 no inj pulse
Hello,
Do you have any power at the injector plugs , ( check them all ) allot times in these cars the wire harness going to the injectors rots ( and the wires in the harness to the injectors becomes detached .) THUS NO PULSE ,
Some times if you wiggle the harness you'll see the momentary contact happening.
Dp951
dp951 is offline   Reply With Quote
Old 03-26-2017, 07:44 PM   #3
PaulStewart
PaulStewart's Avatar
If you still need one, PM me the part number on yours so I can check my inventory.
PaulStewart is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Fuel pump issue, this one is complicated - Help me pls. SpeedFrK 944 Turbo and Turbo-S Forum 2 05-17-2016 10:52 PM
Diy dme testing? 85 N/A 944 & 944S2 Forum 4 02-28-2016 01:39 AM
Rogue Tuning ECU - the first production batch is in! Rogue_Ant 944 Turbo and Turbo-S Forum 45 05-28-2014 04:50 PM
no pulse to fuel injectors? ggrecian 924/931/944/951/968 Forum 14 01-06-2014 09:26 PM
1984 Porsche 944 2.5L DME (ECU) question ibtisam.jawad 924/931/944/951/968 Forum 18 10-22-2011 04:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
