924 window button repair? - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 02-01-2017, 03:56 PM   #1
dubdub
User
Default 924 window button repair?
So finally got around to working on the windows, and I think i found the reason they were not working. A fuse was dead. So i replaced it and then i turned the ignition and smoke came out of the button, and it killed the new fuse. so i took it apart and one of the pins was upside down. Is it dead? Any way to fix it or do i need to hunt down a new one?
Heres what it looks like.
dubdub is offline   Reply With Quote
Old 02-01-2017, 10:42 PM   #2
snb13
User
snb13's Avatar
Put it together properly and it should be fine.
snb13 is offline   Reply With Quote
Old 02-05-2017, 11:19 PM   #3
dubdub
User
I tried but it still didnt work, I think it got fried. There's some on ebay for $15, think I'm gonna order 2.
Old 02-14-2017, 03:04 PM   #4
dp951
dp951's Avatar
Default David pagan 924 window switch
Hello, by looking at your pic the plastic pin that hold the spring and ball looks melted , when the buttons get too hot and the stem melts ( high resistance ) , your better off getting one that doesn't have that damage so the spring can move up and down freely thus giving a firm contact ...hey but keep the contacts for spares. I had the same issue with the ealry 944s , also make sure you check and clean the fuse contacts , to insure a good electrical contact. ( 16 amp fuse )
dp951 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Sport mode button not working Alex W General Porsche Discussions Forum 0 09-26-2016 01:56 AM
Coils, spark plugs, O2 sensors and fuses - the adventure! Jeff928S4 Porsche Cayenne Forum 2 07-27-2016 01:52 PM
Bottom positions of door windows are different and one touch does not work ievsdoma 987 - 981 718 Forum 2 03-28-2016 05:34 PM
2006 Cayenne S Bose Radio/CD Fix Bushfoot Cayenne DIY 1 03-19-2015 04:27 PM
Fuse Blues prescott 928 Forum 17 02-08-2015 05:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
