924 and 931 Forum 1976-1988
924 2.0 won't start
Old 01-21-2017, 02:18 AM
pa951
pa951's Avatar
Default 924 2.0 won't start
Well i have been searching and reading lots of topics about non starting 924 but no help.
Have a 1981 924 2.0 car had been standing for a few years. Then i bought it. It ran but only with high (3000rpm) idle. I thought it would be dirt or something like that.
I changed the belts, rotor, sparkplugs and waterpump and now the car simply does not start.
I had timingmarks on cam and flywheel alligned. Checked the distributor. Changed back the old sparkplugs, cap etc but it just wont start..
what could it be? Driving me nuts
I smell fuel, and the sparkplugs are wet
https://youtu.be/vKkXVr0uVlY
Sounds like it has trouble turning the engine round. Starter?
Old 01-22-2017, 04:48 AM
mel_t_vin
mel_t_vin's Avatar
What is the voltage drop across the battery terminals? Have you checked, and re-checked, all power/ground connections, especially at the chassis, battery, and starter?
Pull the battery...will it start a different car? No...time for a new battery. Yes...time for a new/rebuilt starter.
Old 01-23-2017, 12:53 PM
pa951
pa951's Avatar
New battery And starter is ok.
Old 01-23-2017, 12:58 PM
pa951
pa951's Avatar
Cilinder 1 is tdc
Cilinder 1Name:  58105528-A478-48EC-A43B-BADEF01B7DEB.jpg
Cilinder 4
Quick Reply: 924 2.0 won't start
