Does anyone make something like the Gabriel Ready Mount Struts?
Good morning, planning on replacing the struts on the porsche, but to be honest, Im not a big fan of trying to remove the spring. So my question is does anyone make something like the gabriel ready mounts so you can just drop it in?
I've not heard of a Ready mount ? Is it a complete strut / spring and
top mount assembly ?
If not any change of shock absorber is going to need the top mount undoing and the spring removing, it's not that hard to do DIY and would not be much cost with any Car garage either !
R
R
R
Rainman
The 944 has enough suspension "swing" and fender cut outs that you can remove the spring/strut without needing to compress anything.
Lift the car up in the air and unhook the sway bar from the control arm attachment points.
Put the car back on the ground and loosen the strut top nut until it is on the last few threads.
Slowly lift the car back in the air...the weight of the tire/wheel/etc will cause the suspension to droop and de-compress. Remove the strut top nut the rest of the way.
Usually worn struts will pull themselves from the upper strut mount but sometimes a light whack on the top of the strut will put it through the hole.
The spring will now be loose, you can use your arm strength to wiggle/lever the whole strut slightly towards the back of the car, and then tilt it outwards. Remove the spring, remove the strut insert (or the whole body if a sealed strut car).
As they say...installation is the reverse of removal.
Getting to the point of swapping the strut out is about a 10 minute procedure following these instructions.
Yes, its complete spring, strut, and the top piece. I know its not hard to do DIY, but im not a big fan of compressing that spring. The local garage wants $800 for the struts... and hes not using Bilsteins. And that doesnt include an allignment. If I have to, I guess Ill be rebuilding it.
$800 to change 2 shock absorbers ! This is way over the top....
Surely there will be other garages that would more like $400 including supply, fit and alignment ?
An new shock Insert is only about $100 ?
R
Rainman
If your car is a "removable strut insert" type, doing both fronts and both rears should take maybe an hour, total.
The parts will be $300-$400 on their own though for basic Sachs/Boge parts.
Gabriel/Monroe shocks are GARBAGE.
The problem around here (suburbs of philly) the shop rate is 100 per hour, so jobs get expensive real quick. They also mark up parts up to 50%. Its very frustrating.
Looks like the previous shocks were Monroes (they are junk)
I have a long driveway, so it takes a while to drag tools down, and when I work on my own vehicles, I take my damn good old time. The longest part of the job is taking and putting tools back. Lol.
The label wore off, and frankly (not being rude) I didnt care, car failed inspection because of them.
Pictured above are the rear shocks that were on the truck, old on left, new on the right. I usually wait a long while to do shocks on my vehicles.... so unless inspection fails them, I usually dont do them.
