924 and 931 Forum 1976-1988
torque tube noise?
Old 08-13-2016, 11:34 PM
jjmohler
jjmohler's Avatar
Default torque tube noise?
I have a '88' 924s and it makes a rattling noise on decel at lower speed after it is warmed up. It sounds like a heat shield but i have not been able to find the source. Could it be coming for the torque tube? I had the same condition with my 951 and never did find the source.
Old 08-17-2016, 05:51 AM
mel_t_vin
mel_t_vin's Avatar
How long has this been happening? What gear oil is in your box? How long/many miles has it been there? With the clutch engaged or disengaged? Has anyone else listened to this rattle?
Rattle at idle, in neutral, with clutch engaged is usually a throw out bearing. Rattle on decal, in gear, with clutch engaged could be torque tube bearings, ring & pinion, or gear box bearings.
Would attempt to record the sound and reach out to Kevin Gross.
Quick Reply: torque tube noise?
