1988 924s "Name that electrical Part"
Car runs great with "Jumpers" however, when I hook up new DME, or spare used DME the fuel pump powers up and it turns over but no start? I was guided to my ignition switch. As I was looking around I found various bits and pieces that need to be addressed. If I could get help identifying these two I would appreciate it.
Both look like relay sockets. The connector in the first and second photos is 803 971 835 A, I think. Without spending a lot of time poring over the wiring diagrams, cannot tell what they would be for.
Post your questions here: http://www.924board.org/index.php
Or do some searching there as well. The five hole plug attaches to a relay which is attached to the side of the yellow HVAC tunnel. Not sure what it does though, could be a fan relay. Mine activates when I turn the key on. What is the ECU looking thing under the center console? Haven't seen that before.
Thanks for any info. The PO just kinda disconnected everything and I'm just trying to get everything sorted. As for the ECU looking thing, I have no clue? I wish it was an alarm. I though for sure my "No start" issue was related to a faulty alarm however, after looking in the passengers foot well I came to the conclusion this car has no alarm. My goal here is to get everything sorted to figure out what my no start issue is? Another problem I've been having is most of the wiring diagrams I've been looking at the wire colors don't match my car, is this common?
