924 and 931 Forum 1976-1988
Rad fans not working
Old 05-27-2014, 06:40 PM
C.pan974
C.pan974's Avatar
Default Rad fans not working
Have just noticed that my rad fans are not working. I have never had my car over heat yet, but when I'm idling in traffic my gauge goes up rapidly. As long as I'm moving it stays remarkable at optimal temp. I checked to see if the fans in deed are not working, and they do not. I have checked to make sure they are connected at the fan and they are. Could it be just a fuse or a relay? If so, which would it be and how would I access the fuse box.
Old 06-01-2014, 02:45 PM
C.pan974
C.pan974's Avatar
Am I correct in saying that fuse #3 should be for the rad fans? If so does anything look wrong? I checked the contacts and they seem fine. What else could I check? I've checked the connection to the fans themselves and again they are fine. I'm stuck as for what to do.
Old 06-01-2014, 03:09 PM
C.pan974
C.pan974's Avatar
Should there be something here? Because I don't see anything matching the pelican picture.
Old 06-04-2014, 02:02 PM
turboS_swede
turboS_swede's Avatar
What year are we talking about?
Have you poked around on the 924board? Lots of knowledge there on the 924.
Like this post for example:
http://www.924board.org/viewtopic.ph...91058744468ed4
Old 06-04-2014, 02:11 PM
C.pan974
C.pan974's Avatar
I checked on a few places. They said to check around the ground wires for debris. While I was checking the grounds I realized that the thermostat wires were green and lumpy with corrosion. I'm assuming that this would be the reason for malfunction. I figure it wouldn't be a bad idea to just replace the thermostat, plug and connectors because of it. They're about $15 each on pelican. I have no idea how I missed that corrosion though, while I had my engine out last summer. It's on my 87' 924S. Anything I should check as precaution? I'll be working under my car till this Saturday (June 7) working on my new tie rod ends, shocks and bushings.
Quick Reply: Rad fans not working
