924 and 931 Forum 1976-1988
Hatch air shocks.
Old 05-09-2014, 08:19 PM
C.pan974
C.pan974's Avatar
Default Hatch air shocks.
Need new shocks for my 924S rear hatch. I'm looking on pelican and there is only an option for hood shocks. Are they the same as what is required for the hatch?
Old 05-11-2014, 09:30 AM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
Hood=front
Rear lid, decklid or Hatch=rear
..and, the usual outcome if you install new rear hatch shocks is separation of the metal frame to the glass.
J_AZ
Old 05-11-2014, 09:48 AM
C.pan974
C.pan974's Avatar
So, what you're saying is I shouldn't replace them? What should I do, is there a way to refurbish them?
Old 05-11-2014, 09:54 AM
John_AZ
John_AZ's Avatar
I have always bought "good" used from members/ebay and they last about 3 or 4 years.
J_AZ
Old 05-11-2014, 10:12 AM
C.pan974
C.pan974's Avatar
I guess I'll keep looking for parts cars then. Thanks for the tip. And one other hatch related thing. One of my hinges squeaks every time I hit a bump on the road. (There are a lot of these in Winnipeg). It doesn't squeak when I open the hatch though. I've tried oiling it but it doesn't seem to make a difference. How would I go about replacing the hinge? I haven't seen them on pelican.
Old 05-11-2014, 03:09 PM
John_AZ
John_AZ's Avatar
You could check for correct fit or oil:
http://forums.pelicanparts.com/porsc...inge-pins.html
Somewhere I saw Stainless steel replacements ???
Another part that is replaced is the Hatch Pin seats. Buy from the creator:
http://only944.com/partscatalog/only/hatchpinseats/
J_AZ
Old 05-13-2014, 10:22 AM
turboS_swede
turboS_swede's Avatar
Before replacing the hatch pins, get the pin seats from only944 and see if that quiets the rattles (it did on my 951).
If you search around for 924 hatch shocks you should be able to find some posts with lighterweight replacements available online or at the local parts house.
Quick Reply: Hatch air shocks.
