924 and 931 Forum 1976-1988
DME relay question
Old 09-02-2013, 06:50 PM
NSA
NSA's Avatar
Default DME relay question
My fuel pump won't run when ignition is hot and I'm currently at the DME relay. If I jump the 30 (12v in) and 87b (12v out to fuel pump), the pump will run when the ignition is hot, but when I try two different DME relays, the pump just won't run. Car is a 924S / 968 hybrid. 968 engine and DME, 924S basic wiring.
The DME has power going to 86 (hot) and 30 (always).
Pin 85 [1] - Ground to the DME/injector relay coil - OK
Pin 30 [2] - +12V directly from the battery - OK
Pin 86 [3] - Switched +12V from ignition switch (bus 15) - OK
Pin 87b [4] - +12V to the fuel pump, switched by the fuel pump relay - OK when jumped
Pin 87 [8] - +12V to the DME and fuel injectors, switched by the DME/injector relay - OK
Pin 85b [9] - 0V switched to the coil of the fuel pump relay from the DME, pin 20
How do I check 85b? It has 0v, but I guess this isn't the same as checking the ground.
Any ideas? Please don't say my DME might be fried.
Old 09-16-2013, 02:46 PM
snakoil
snakoil's Avatar
I can't remember how to test it but I did have my DME relay failed
You do know you can simply order a new one at your local VW dealer for 30$
Note that I ended up ordering 2 as the first DME relay I bought at the dealer was DOA
took me almost a full winter of fiddling to realize new item was DOA ;-)
If I remember well I ended up with a revised version of the relay that was in the VW golf.
Old 10-26-2013, 07:34 PM
NSA
NSA's Avatar
I replaced the fuel pump, DME relay, and cleaned up the wiring and the car fired up as normal.
Old 10-29-2013, 04:28 PM
toms59
7th Gear
toms59's Avatar
Very common problem with the DME relay as it gets hot and can fail with age.
Quick Reply: DME relay question
