Upgrading my 951, in search of 300RWHP.
Ok, I've already got the engine out and taken apart. I'm going to rebuild it, and replace the turbo.
I currently only have the following modifications: 1) No cat. 2) Autothority(sp?) chip. 3) Dual Port Wastegate. 4) Manual Boost Controller.
I plan on running the car @ 14.5PSI, what the performance chip calls for.
What I'm after is, 300RWHP. I see on SFR's website the stage I turbo can do 325 @ 16-18psi.
My main question is, if I'm going to run this turbo @ 1bar, do I definately need larger injectors or just an Adjustable Fuel Pressure Regulator, or both?
If I do need the AFPR, or both - would using a good A/F ratio gauge in my gauge pod be sufficient to ensure I'm not running lean? Or is there another way I personally can make sure I'm running somewhere close to 12:1 A/F? (I think it's 12:1 i'm after)
I'd look into the lindsey racing 300rwhp kit.
If you upgrade the turbo upgrade the injectors..I have a 60-1 hifi and stock injectors (hopefully not for longer) and max them out over 14psi..
You'll need both the larger injectors and the FPR. In order for the larger injectors to flow more fuel, they need greater fuel pressure. An A/F ratio guage is always a plus, but not 100% needed. If you buy from a reputable vendor, then you don't have to worry so much about running lean.
We did a 951 with stock injectors with guru stuff . I don't recall which turbo but I know it wasn't stock . We had to run it at 18 psi stock cam . It put 299 hp to the ground with Great o2 #s .Aaron and I worked on the car together on the dyno . I was inside working with the Version coding and the calif. switch that delays the ign. He was outside playing with the AFM and putting resistors in the NTC2 . We finally realized the only way to get the o2 #s good was to put in the 3 Bar regulator . That fixed alot .
We also just built a NASA motor that put down around 310 with a stock turbo and injectors with an aftermarket cam and no head work on either .
