924 and 931 Forum 1976-1988
fuel pump in the 931
Old 02-25-2008, 07:07 PM
Pcarkid931
6th Gear
Pcarkid931's Avatar
Default fuel pump in the 931
hi,
i was driving my 931 and the rpm's started to drop to 0 then jump back up. i have suspition that the fuel pump may be bad just wanted to see what you guys think. thanks!
Old 02-28-2008, 03:17 PM
924RACR
924RACR's Avatar
Depends - how quickly did they drop? If it's instantly, like shutoff, you may have glitchy wiring on the ignition controller - what year 931?
Also, if it does turn out to be fuel-related, have you already changed your fuel filter? Does it face the correct way (flow is to the rear of the car)? If it's facing the wrong way, replace it with a new one pointed the right way.
Old 02-29-2008, 12:47 PM
Buwani 931
Buwani 931's Avatar
That is assuming you are left hand drive.
Shawn
Old 03-01-2008, 07:38 PM
924RACR
924RACR's Avatar
Yes, it is; good point though, I didn't realize they're the other way around in RHD?
Old 03-01-2008, 09:16 PM
Buwani 931
Buwani 931's Avatar
Yep, RHD filter is where our battery is and goes directly up toward the fuel distibutor rather than back,sideways, and then forward like a LHD.
Shawn
Quick Reply: fuel pump in the 931
