1970 914/6 Harness Horror - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 08-10-2016, 11:49 PM   #1
howie149
New User
Default 1970 914/6 Harness Horror
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires.
Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul.
howie149 is offline   Reply With Quote
Old 08-11-2016, 07:10 PM   #2
dr914
User
that is an easy one, we have the factory six wiring diagram as well as the conversion wiring diagram available, plus a new rear relay board bulkhead plug! If the car was in our shop we would have you all fixed up in an hour. Of course looks like someone MADE the engine wiring harness so not all wires are the factory color code, but it is certainly simple enough to repair
dr914 is offline   Reply With Quote
Old 08-11-2016, 10:55 PM   #3
howie149
New User
Where is your shop?
Old 08-12-2016, 05:21 PM   #4
dr914
User
Automobile Atlanta in a suburb of Atlanta, probably way to far to travel
Related Topics
Thread Thread Starter Forum Replies Last Post
Oil choices smokersteve 914/914-6 Forum 6 06-09-2016 08:55 PM
Oil Pressure sender terminals FredR 928 Forum 6 05-12-2015 10:27 AM
914-6 1970 for sale brucefairman 914/914-6 Forum 2 04-14-2015 08:50 PM
Old-Fashioned Porsche Racing Wheels jforbes Parts Marketplace 0 09-20-2012 09:16 AM
1970 Porsche 914/6 Vincent racecar BUTTRY924 914/914-6 Forum 8 12-06-2010 03:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
