914/914-6 Forum 1969-1976
1970 914/6 Harness Horror
Old 08-10-2016, 11:49 PM
howie149
7th Gear
howie149's Avatar
Default 1970 914/6 Harness Horror
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires.
Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul.
Old 08-11-2016, 07:10 PM
dr914
dr914's Avatar
that is an easy one, we have the factory six wiring diagram as well as the conversion wiring diagram available, plus a new rear relay board bulkhead plug! If the car was in our shop we would have you all fixed up in an hour. Of course looks like someone MADE the engine wiring harness so not all wires are the factory color code, but it is certainly simple enough to repair
Old 08-11-2016, 10:55 PM
howie149
7th Gear
howie149's Avatar
Where is your shop?
Old 08-12-2016, 05:21 PM
dr914
dr914's Avatar
Automobile Atlanta in a suburb of Atlanta, probably way to far to travel
Quick Reply: 1970 914/6 Harness Horror
