Salvaging a toasted 2.4/4 back to 2.0 or so? - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 06-05-2016, 07:39 PM   #1
914tim
Default Salvaging a toasted 2.4/4 back to 2.0 or so?
I acquired a nice 914 with a 2.4 /4 engine. Ran very strong but was leaking oil around the cylinders and cam seals, etc.
Local Porsche shop disassembled the engine and recommended against trying to seal the cylinders to the case as it had very little surface remaining.
So here's the question.
Assuming the crankshaft and camshaft are still good and I do want to keep the Dellorto 45's and 1 5/8 European racing headers( no heat exchangers) and use the front oil cooler(Patrick GT Conversion).
I’m thinking I must find a 2.0 Short block, or will a 1.8/1.7 case work?
Obviously I will have to find barrels and pistons for whatever case I use.
Rod journals on a 2.0 are smaller, so if I keep the crank I must use a 2.0 case, eh?
I found a set of 2.0 heads today at the PCA swap meet, hopefully they will check out.
Final question, what are those 2.4 cylinders & Pistons and heads worth?
Thanks for reading.
Cheers
Tim
914tim is offline   Reply With Quote
Old 07-28-2016, 05:09 PM   #2
dr914
User
no one cuts the case these days and installs those 104 pistons and cylinders as it ruins the case and runs very hot. You can use a 1.7 1.8 case yes, the 2.0 just a little more relieved for piston skirt clearance. Try to get a case through 74 with the dual oil pressure relief valves as those cases are much superior to the 75 76 style
dr914 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
WTB 914 2.0 /4 short block or case 914tim Parts Marketplace 0 06-07-2016 01:11 PM
WTB 2.0 Long or short Block Nor Cal 914tim 914/914-6 Forum 2 06-07-2016 11:07 AM
73 914 (great 914-6 conversion) for sale sdrake Vehicle Marketplace 4 12-26-2015 02:27 PM
Sealed the case, 2 extra o-rings! Aargh sundog 964 Forum 10 12-05-2006 03:07 PM
...and for post number 930 - REBUILD P@RN sand_man 911 Turbo (930) Forum 21 06-16-2006 10:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 1998 - 2015 Rennlist.com
