Rennshift Recommendation
We've just completed my 914/6 conversion in which I stayed with the 901 side shift tranny. What is the conscenus about installing a Rennshift short throw shifter on this car?
Official Wednesday AM Red Bull F1 test driver
Have Rennshift on both my 914's. Good product and greatly improves shifting. Does require some adjustments to make it work right. Not a simple plug and play...
Ski,
Thanks for the reply. From doing research, I did find that adjustment can be an issue. However, Tangerine just came out with an easily manipulated adjustment device that they sell for about $190. Are you familiar with the device, and if so, do you think it would address your comment about difficulties in setting the shifter up?
The device uses a rack & pinion worm adjuster to make small changes in rotation of the shift rod, which should eliminate the need to use trial and error to find the right spot.
Basic Sponsor
I have Rennshift on both 914's and will never have one without it. I actually never had to adjust anything...plug and play for me. Both on 901, and now a 915 in the race car. In the 'street' car "Huey" everyone is amazed how perfect the shifting is. I can't say enough good things about the product.
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
I have seen the adjustment deal Chris sells and it could help. The back and forth adjustment can be a pain to get right- Bob must have been lucky. It took a while with my '71 but I was also converting from tail to side shifter at the same time. Side to side was easier on the '73, but did have to play around a little for the fore and aft adjustment. Worth the effort.
