914 Suspension Upgrade-What's best?
I just purchased a 72 914 2.0 which is my first 914. I want to improve the suspension which I'm pretty sure is worn out and would appreciate any recommendations those of you have for what the best setup is. My guess is I'll need shocks/coilovers on all corners, but am curious what spring rates, type of shocks etc. work best for the street on this car.
I have other track cars so don't need anything suited for that purpose. Just want to get the most out of the car with the correct street setup. I'll appreciate any help from those who have developed knowledge around this. Thanks all.
Brad
Brad
For a great street vehicle + some DE track time, I put Koni/gas at all 4 corners, with adjustable coil spring perches out back. Boges if you are on a budget, Bilsteins are right in the middle of cost range. If you are serious about front coil-overs, you could go RSR front struts with the coilovers; OR the JRZ brand struts, shocks + coil overs ;WARNING; the prices get into the stratosphere !
Marty
Marty
Thanks for your help. The JRZs are great, but not what I need on this car. I think I'll replace the Struts and coil overs with Bilstein and bump up the rear springs a bit to 140 lbs. or so. For the first time in history, I'm not going to go crazy on this car......just want it to drive nice on the street. Thanks for the response.
On my personal 914's I've used, Koni Yellows, 19mm front sway bar, 21mm front torsion bars and threaded adjustable setup on the back with 150-175# springs.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Since it is a street car, one of the best restoration tips is to replace all the OEM rubber bushings with rubber. The stock 914 suspension was pretty stiff to start with. Put in new rubber and you will be amazed. If you decide to "upgrade" to Delrin or the like you will get a bone jarring ride. Guaranteed.
I concur 100%. I have had the hard bushings in other 914-6's and this time around I went with all Elephant Racing rubber bushings. I want it to be responsive but not bone jarring. I am also done with squeaks at this point in my life. Unless your car is a dedicated track car, I see no reason for any other type of bushings. As for coil-overs, I love them. But I went with just Bilstein Sports on my Six this time around. Essentially to keep the stock configuration as much as possible.
I would simply put it back the way it was with the addition of bilstein shocks
new tie rods
new ball joints (look at the bottom of the 72 strut to balljoint hole for wear
new front wheel bearings
front bilstein shocks
rear stock spring set
rear bilstein shocks
rear wheel bearings
rebuilt cv axles
195/65x15 tires on 5.5 rims
that should set up a street car nicely. No need for sway bars or heavier springs
new tie rods
rear wheel bearings
rebuilt cv axles
Brad
Brad
