914/914-6 Forum 1969-1976
Porsche 914 - 8 GTT The Build Begins
Old 09-27-2013, 07:33 PM
Maltese Falcon
Maltese Falcon's Avatar
New cnc machined T6 aluminum dry sump oil pan, outboard scavenge pump, and about +9" more ground clearence. Perfect to lower the cg of this engine.
Old 09-27-2013, 07:47 PM
Maltese Falcon
Another engine view from the bottom of the new cnc oil pan. Oil scavenge pump off to the side, and new 60 tooth ecu trigger ring for Haltech engine management.
Old 10-03-2013, 10:36 AM
Mike Simard
Mike Simard's Avatar
What a great idea!
I just got a 914 that looks like yours and want to just drive it, I hope this all doesn't rub off on me.
Is that a RT DASH2 you're using?
Old 10-03-2013, 09:01 PM
Maltese Falcon
Mike, the dash we decided on is the Haltec model# IQ 3 dash with data logger and SD card . It operates via the Haltec # PS 2000 ecu (platinum series). The oe Cayenne ecu could probably be tuned for our needs, but the Haltec will be a lot easier for trackside tuning.
MarTY
Old 10-04-2013, 07:12 AM
Mike Simard
Why is the trigger wheel mounted up front? It looks like it's attached to the movable part of a damper, is it?
Old 10-05-2013, 04:06 AM
Maltese Falcon
Mike...the engine builder uses this method for the 60 T trigger ring(front of engine rather than rear) as there is inadequate space aft in the bellhousing. The oe Cayenne has a large + bulky trigger ring attached to a flex plate, which is not being reused with the gt-2 transaxle. The front dampner is not a stock part, I can investigate it some more when the engine arrives back in Glendale .
Old 10-05-2013, 02:10 PM
cordsig79
cordsig79's Avatar
subscribed, coming over from the cayenne forum.....I wonder how easy it would be to just put the same engine in my cayenne ....
Old 10-11-2013, 10:21 PM
MATTYLITE
MATTYLITE's Avatar
Update:
The Haltech Platinum Series Sport 2000 came in today. This ECU is a complete a la carte set up.
Everything that came in was perfectly packaged.
Not to mention everything is already pre - labeled!
GPS Certified MPH / KPH
The Haltech IQ3 Logging Dash w/ SD Card for saving everything.
Old 10-13-2013, 12:39 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Any photos of the chassis work?
Old 10-13-2013, 01:11 PM
CVDH
CVDH's Avatar
Been watching this one. Interested to see how you plan on integrating the Haltech unit into the dash.
Old 10-25-2013, 02:55 AM
MATTYLITE
MATTYLITE's Avatar
Here is a BIG update that we're very happy to share with you all. This has been several months in the works, and have finally arrived. Forgeline Motorsports set us up with a set of their GT Style Centerlock Long Nose adapters. They are Carrera GT inspired, red per the driver side, blue per the passenger side.
For your reference: (apologies for the grainy cell phone picks)
Darkstar1 (06-10-2023)
Old 11-01-2013, 04:18 PM
cds4402
cds4402's Avatar
Subscribed! Very interested in seeing how this turns out.
Old 11-01-2013, 09:38 PM
skl
Official Wednesday AM Red Bull F1 test driver
skl's Avatar
Centerlocks on a 914??
Gotta admit I look the looks on my GT3, but I can change wheels a lot faster on the 914 with plain old studs and wheel bolts…and the classic Fuchs.
Old 11-01-2013, 10:38 PM
FlatSix911
FlatSix911's Avatar
I can build the HID lights ... let me know if you are interested.
Old 11-02-2013, 02:10 AM
MATTYLITE
MATTYLITE's Avatar
Do you have any examples you can show or link to?
Quick Reply: Porsche 914 - 8 GTT The Build Begins
