914/914-6 Forum 1969-1976
Porsche 914 - 8 GTT The Build Begins
Old 05-22-2015, 08:13 PM
  #106
Maltese Falcon
Maltese Falcon's Avatar
I shaped these door bars to allow easier leg swing during entry/exit for the "Business office".
Old 05-31-2015, 05:57 PM
  #107
Maltese Falcon
...and a small amount of Dremel work to the inner door frame;
Old 05-31-2015, 06:12 PM
  #108
Maltese Falcon
Right side door fitted, now off to the paint stripper !
Old 05-31-2015, 07:01 PM
  #109
mklaskin
mklaskin's Avatar
Why not fiberglass or carbon doors?
Old 06-01-2015, 10:56 PM
  #110
Maltese Falcon
We are using the '74 doors with the DOT reinforcement. Also using these steel doors as a good frame attaching point for the plexiglass slider windows. I may use some Sheridan 914 f'glass door skins in the future.
Marty
Old 06-02-2015, 12:19 AM
  #111
mklaskin
mklaskin's Avatar
Marty
I see. Please keep the updates coming.
Old 06-06-2015, 04:15 AM
  #112
Maltese Falcon
More progress, both door cages layout complete...more welding next week.
Old 06-06-2015, 04:39 AM
  #113
Maltese Falcon
Left rear air jack , tripod support plates welded in place.
1/4" npt opening at the top is for the air line, which will raise and lower the 914 for tire change duty.
Old 06-13-2015, 09:38 PM
  #114
Maltese Falcon
Completed welding the left and right side cage-work.
Old 06-13-2015, 09:44 PM
  #115
Maltese Falcon
Finished welding in the left and rear air jack guide plates.
A bit more fabrication in the cabin cage work next week...
Old 07-18-2015, 03:09 PM
  #116
Maltese Falcon
More strength+ safety
Old 07-18-2015, 03:13 PM
  #117
Maltese Falcon
Fitting rear quarters
Old 07-18-2015, 03:26 PM
  #118
Maltese Falcon
Inner support for quarter panel...using the Sheridan wide body. In the top pic the small wing nut is holding to a small area of left-over original fender mtl.
I later boxed this bracket in for strength, works perfect. The oe fender support struts are cut away, in the wrong place for the new quarter panels. I also trimmed and left most of the rear sheet metal roll pan. It will graft into a new structure for the under body ground effect diffuser.
Old 07-25-2015, 09:20 PM
  #119
Maltese Falcon
Fitting dzus fasteners to the R-rear qtr. panel, pardon the dusty body panel...this is a construction site
Old 09-17-2015, 04:32 AM
  #120
944crazy
944crazy's Avatar
Holy ****, this thread is amazing! What a build, can't wait to see where this goes.
I have often fantasized about one day building a Beck 904 replica with a turbo cayenne v8 in it, so it was pretty awesome to come across this thread.
Good luck, and keep us updated!
Quick Reply: Porsche 914 - 8 GTT The Build Begins
