914/914-6 Forum 1969-1976
suggestions for a 914 Spec
Old 11-23-2011, 09:29 PM
racer
racer's Avatar
I ran Porterfied R-4S pads in my stockish '76.
Weight?
My early 1970, with carpets out, full tank of gas was 1990lb w/o driver.
My late 1976, similar set up, was closer to 2200lb w/o driver.
2100# with driver means a 1950# or less car. The only stuff that made the late cars heavier was added safety stuff (bumpers, door beams etc). Using stock steel panels, there isn't a lot of weight to take out, unless you cut off the windshield.
In the mid 1990s I recal several friends doing a similar thing. Theay each bought a stock 1.7/1.8 and had at it. Fun, if only because they then had someone to run with. That lasted for about 1 season.
x100 that a $1500-2500 isn't worth the effort, typically.. but if from a dry climate, maybe its still possible?
Check out "tangerine racing" for header ideas.. and triple the price of the car. Don't foget center tunnel plastic fuel lines will need replacement.
Once you factor in a cage, seats, and all the other "spec" stuff, imho, you are easily spending "944 spec" money.. but have a slower car.
Better off builind up a PCA GT6(?) class car instead, imho.
Old 12-01-2011, 07:31 PM
NaroEscape
Basic Sponsor
NaroEscape's Avatar
Originally Posted by Jagbuff
...any good cheater tricks are also welcomed
PS: still looking for donor (solid) car, please PM
Build your 1.8 to a 2.4. it'll be really fast... and look like a 1.8 from the outside.
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
  • Data Analysis & Coaching
  • Drivers Gear
  • Crew Gear
  • Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Quick Reply: suggestions for a 914 Spec
