Still Searching For The Answer...
My '74 914 1.8 now starts well and idles pretty good. However, it refuses to smoothly accept throttle, instead of revving it bucks, shakes violently, sometimes even backfires in the exhaust.
My question, have any of you run across an issue like this that was caused by piston rings seized in their pistons? My compression ranges from a low of 108 to a high of 112. This might be too low across the board but I don't know/have a spec for what is acceptable. Also, when I did the valve adjustment I discovered a lot of condensation rust in the valve covers.
Thinking back on that rust I'm beginning to wonder if the piston rings are sufficiently stuck in their ring grooves to affect what's happening in the combustion chambers. In review, I have a perfect ignition system, a very good FI system with many new parts, and no air/vacuum leaks. I have not put Marvel Oil or an aerosol spray (like PB Blaster) into the combustion chambers.
Rennlist Hoonigan
which cost no drachmas
It's been a long time since my motor was stock, so I don't exactly remember, but I think my compression numbers were around 130-140 lbs. Do a leak down and you'll learn a lot more very quickly.
Trying to remember the fuel injection system - where does it have potentiameters? Does it have a tps? One for the maf? Are those putting out good signals?
Just because you relented and told me that you will sell your basement boat anchor to me doesn't mean that you have Carte Blanche to be a thread hijacker!
Sheeeesh...
Sorry Pete! I am sorry for stealing your thunder. I feel since I can't offer and actual help I will at least bust people's ***** from time to time.
Matthew, thank you for clearing up my error.
One thing that puzzles me is that my timing light (a good quality, but old, SnapOn unit) kept shutting off, then coming back on, as I tried to rev the engine (on a 1.8 L-jet engine the timing is set at idle at 7.5 degrees BTDC) to see what the distributor advance was doing. I did not get back to that because I ordered a new spark plug wire set (just delivered) but haven't had time to install it and re-check timing again.
Rennlist Hoonigan
Is the coil or points signal bad?
You should be really nice to Racing916 and get him to ship his good 1.8 out to you. Anything from him is going to be A+.
The weather is supposed to be hot for another day, so I'm going to spray PB Blaster into the cylinders tomorrow, hopefully it'll reach the rings, and try to get the car running again on Friday morning. Voltmeter on the coil will be my priority.
