1970 Porsche 914/6 Vincent racecar
1970 Porsche 914/6.
Title: 1970 Porsche 914/6 Vincent racecar
Mileage: 95,000 miles
Vehicle Information
VIN: 914-043-0830 gets the vehicles history reports
Warranty: vehicle does not have an existing warranty
Title: clear
Condition: Used
For sale by: Private Seller
Features
Body type: convertible
Engine: six cylinders
Interior color: yellow
Transmission: manual
Fuel type: gasoline
Interior color: black
Disability equipped: N/A
This is one of 3332 Porsche 914/6 made by Porsche. It is a 1970 model and has been completely rebuilt by Emory Motors Sport. Last tuned by Joe Scneider in Santa Barbara. With a 914/6 GT in mind, the goal was to create a car primarily suited for vintage racing but also for some normal street driving. The car has rarely been used and is ready for your racing engagement.
The work performed by Emory includes:
Engine
- New oil pump 911.107.008.05 (3.0 SC)
- New oil lines.
- Oil cooler sonic cleaned and tested
- Distributor reworked by Don Marks at Gearhead Co.
- Rods shot peened, rebuild and re-bushed. New rod bolts.
- Flywheel surfaced.
- Crank polished and balanced with flywheel.
- Cam towers and rocker gear rebuild and resurfaced.
- Cams ground to “E” specs for exhaust and “S” for intake.
- The carbs rebuild with new carb kits.
- Two heads replaced.
- Heads rebuild with new valves and seat cut.
- New piston and cylinder set 9:1.
- New guides, new springs, etc.
- Triple 40mm Weber IDA carbs.
- K&N air filters.
- MSD ignition box.
- Final assembly with all new bearings.
- 146 HP on the dyno after many improvements.
Transmission
- The car has a 901-side shifter transmission.
- All the syncros have been replaced.
- New racing clutch.
Suspension
- Trailing arms boxed.
- Chassis stiffening kit installed.
- Weltmeister rear race springs.
- Sway bar 19mm rear /22mm front.
- Turbo tie rod kit.
- Polygraphite bushings.
- Hydraulic parking brake.
Wheels and Tires
- Fuchs 6x15.
- Yokohama A032R 205/50 VR15
Other
- Lexan windshild (front and rear).
- Custom 914-6 GT style roll bar.
- New rotors and calipers.
- Sparco Evo 3 Racing seat (Passenger & Driver side).
- Light weight carpet kit.
- New door panels.
- 5 point harness.
- New rubber seals.
- New shift ****.
- New rear view mirror.
- Safety fuel cell
- Sport and stock muffler.
- Emergency electrical shut off.
- Rebuild gauges.
Vehicle Information
Title: clear
Condition: Used
Features
Fuel type: gasoline
Engine
- New oil lines.
- K&N air filters.
- MSD ignition box.
Transmission
Suspension
Wheels and Tires
- Fuchs 6x15.
Other
- New door panels.
- 5 point harness.
- New rubber seals.
- New shift ****.
- Safety fuel cell
- Rebuild gauges.
No it does not have a logbook. The previous owner only had the car for 8 mouths and just got the car to fit him correctly (new seats and steering wheel). He had not decided on a race group yet because he just got the car and wanted to do some track days first. Well the owner got sick and will not be able to have any fun with the car because medical reasons. Oh yeah, the engine is a 2.0L.
$24000 OR BEST OFFER. ANY REAL QUESTION, PLEASE CALL ME OR EMAIL. mastercraftsbrob.com or (805) 965-5261. Ask for Robert or Seth if calling. THE EMAIL ADDRESS BELONGS TO Robert.
