Transmission leak help
5th Gear
I'm a new 914 owner, and I'm trying to get her into shape. The car is leaking transmission oil from the speedo tie-in location. I can't find any information on this connection in my Haynes Manual, anyone know how to "rebuild" this connection. It looks like it's leaking from the trans entry point, from behind a collar.
Thanks in advance.
Thanks in advance.
Hi Brian..!
Yes- the speedometer drive shafts will leak - most commonly around the rubber O-ring.. It makes for a bit of a mess on the garage and driveway floor when they leak.. Fortunately - it's easy to replacement...
1: Drain the oil from the tranny (as me how I know you need to do this!!!)
2: disconnect the speed-o cable from the drive gear...
3: Remove the set bolt from the end-plate of the tranny that holds in the drive gear assy and unsrew the retaining nut...
4: remove the drive gear from the transmission - and you will see the old rubber O-Ring attached around a grove of the drive gear body - that is the one to replace... I got mine ne O-ring from a selection pack at a local FLAPS...
5: Reassemble in reverse order - but be careful not to overtighted the set-bolt that holds the gear in place (also remember to refill your tranny with fluid...)
HTH!!!!
[ 03-06-2001: Message edited by: John D. ]
HTH!!!!
5th Gear
Thanks for the super quick response. I'll take on the job one evening this week. Just one follow up question. You mention not to over tighten the set-bolt. I did put a wrench on the bolt, and tried to tighten it. It turned, but did not seem to tighten up. I was careful with it, and it did not feel like it was stripped. I stopped after a couple of turns. Does this bolt pull the spedo assembly into the tranny? Will over tightening it mash the o-ring, or worse?
Thanks,
Brian
Thanks,
Brian
