Factory 15mm sway bar
Swapped out my aftermarket 19mm adjustable front sway bar with a factory 15mm. I had all the hardware replated with yellow zinc (PMB) like they were delivered so it looks great even though you can't see it without taking the wheels off. It made the ride a little smoother since it has relaxed the front suspension a bit. The 19mm was too stiff and caused the car to under steer or push.
Anyone need the 19mm?
Here's the factory bar drop links.
